Can anyone help with a turbo 400 problem?
Discussion in 'The Garage' started by Trailblzn, Apr 29, 2002.
  1. Trailblzn
    Trailblzn Registered Member
    Feb 26, 2002
    41
    Northern, CA
    I just put a turbo 400 in my blazer. It appears to be recently rebuilt, but it shifts hard into reverse and from 1st to 2nd and 2nd to 3rd. Does anyone know of any common causes and/or easy fixes for this. I would really appreciate any info. Thanks, Scott
  2. lt61173
    lt61173 1/2 ton status
    Apr 9, 2002
    105
    Republic, Pa
    does it have a shift kit. also check the modulator valve it may be bad
  3. Trailblzn
    Feb 26, 2002
    41
    Northern, CA
    I'm pretty sure it has a shift kit, I have had transmissions before with shift kits, but they never shifted this hard. The modulator valve looks new. I priced one and they are only $13 so it's probably worth a try.
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Does it drag out the shifts too? If so maybe you vac. source is weak?
    -Dan
  5. Trailblzn
    Feb 26, 2002
    41
    Northern, CA
    No, it seems to shift at the right speed, but it shifts so hard it jerks the whole truck.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like it has a shift kit that's set on "stun". /forums/images/icons/wink.gif If you pull out the modulator, very gently remove the piston that it presses against. See if there is a spring behind that piston. If not, see if your local tranny shop will donate one to you. Some shift kits have you remove that spring, which results in VERY hard shifting. You can also get different rate springs to put behind that piston to adjust the harshness of the shifts.
  7. Trailblzn
    Feb 26, 2002
    41
    Northern, CA
    Thanks for the shift kit info I will check it out tonight!
  8. Trailblzn
    Feb 26, 2002
    41
    Northern, CA
    Harry - There dosen't appear to be a spring behind the piston, when I pushed it in it didn't push back out. I tried pulling the piston out but it didn't want to come, do you have any secrets on getting it out. Thanks, Scott
  9. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Removing the spring is an old racers trick to getting them to shift really hard. It works great. Leave it that way. It will make the tranny last alot longer. I just rebuilt my tranny in my race car after 3 years or racing and 3 years before that on the street, and everything still looked great. I just did it to be safe since I dont want anything to break and keep me out of the race season.
    Dan
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It was over 10 years ago when I messed with mine. /forums/images/icons/shocked.gif Seems that it slid right out though.
