Can anyone help with brakes?
Discussion in 'The Garage' started by ellero, Aug 6, 2005.
  1. ellero
    ellero Registered Member
    Jan 25, 2004
    66
    Covington, Georgia
    I have an 84 K5 blazer. One day it was running great. Then sat in the driveway for about 2 months, and the next time I got in it I had no power breaks. Its like trying to stop with the motor off. I assume thats the booster, but before I drop a few hundred on a new one, should I look for anything else? Like I said it just stopped working one day and I am NOT leaking any brake fluid. Please help with advice.
    John
    john@acornca.sdcoxmail.com
  2. wildbilzrydn
    wildbilzrydn 1/2 ton status
    Jun 27, 2005
    118
    Joliet, IL
    The brake booster is powered by either your engine vacumn or hydraulic pressure from your power steering pump. If your booster isn't working, check the source of the "assist". Maybe you have a restriction in the engine vacumn or it threw the power steering belt.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hey if its vacuum power then rmeove that black plastic valve deal in the rubber line that goes to the booster, put in a piece of 3/8" steel tube to splice the hose ends backtogether then see if it works, if not then yeah sound slike booster is toasted
    good luck
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Is the brake pedal very hard or very soft?
