can anyone identify this noise?
Discussion in 'The Garage' started by bear, Sep 19, 2002.
  1. bear
    bear Registered Member
    Sep 16, 2002
    31
    Georgia
    my 83 K5 has a 305 V8.........recently I have noticed a very strange high pitched whining noise when the engine is warm. Anybody got any ideas on what this might be? any help appreciated......this is getting very annoying! /forums/images/icons/tongue.gif
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    clogged up emissions?
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Maybe your power steering pump.
    John
  4. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    after being a master tech for many years, im going to make a few common guesses, aside from that, your on your own /forums/images/icons/laugh.gif
    #1 belt--they get looser when warm.
    #2 alt bearing
    #3 p/s pump
    #4 air pump or bearing
    #5 do you have any idler pully's? a/c clutch fryed? clutch fan internals
    you need to poke and prod around, try the old **screwdriver to ear ( the big end for god sakes /forums/images/icons/laugh.gif ) and this may help. if you have to, get a can of something NON_GREASY like carb, or brake cleen, and spray it on one part to the next ( like a bearing surface etc.. ) , one at a time to see if noise go away.also a non greasy spray will help for only a minute , and not stay greasy to slip on belts etc... /forums/images/icons/wink.gif
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I would vote for the smog pump. Pull the belts off and turn stuff by hand (alt., smog pump, ps pump), and see if you can tell what is squeaking.
  6. bear
    Sep 16, 2002
    31
    Georgia
    thanx for the ideas.....I'll check some of that stuff out this weekend...
  7. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If it has A/C check for a pressure leak around the high pressure switch.
    John
