Can anyone price some machine work?
Discussion in 'The Garage' started by BowtieRed, Nov 4, 2004.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    About how much does each of the following cost:
    Deck block
    Shave heads
    from 1.94/1.50 to 2.02/1.60 valve seats
    hot tank block and heads
    port/polish heads
    magnaflux heads
    thanks, just got a motor for $50. I'm going to get an engine kit from northern auto and splayed caps also, along with valve springs and connecting rods. i'm shooting for 500hp, and i really want to get it.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Splayed caps means line boring as well, just so you know.
    As to what that stuff costs, I'd be wrong to tell you, I never look at the prices...I just send the stuff out.
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    http://www.steveschmidtracing.com/ssr_060.htm
    V-8 Valve Grind (Pr).............................................................................................$120.00
    Pro Sportsman Valve Grind & Blend (Pr)............................................................$250.00
    Competition Valve Grind (Pr)...............................................................................$350.00
    Grind Valves (Set)................................................................................................$ 40.00
    Back-Cut Valves (Set)..........................................................................................$ 20.00
    Surface Heads (up to .020) (Ea)..........................................................................$ .25.00
    O-Ring Heads (.041 wire) (Pr).............................................................................$120.00
    Cut Heads for Loc-Wire (Pr)................................................................................$120.00
    Cut for Teflon Seals (Pr)......................................................................................$ 32.00
    Cut for Large Springs (Pr)....................................................................................$ 32.00
    Mill & CC Heads (Pr)............................................................................................$100.00
    Clean Assemble Set Spring Height......................................................................$ 80.00
    Cut for Seats (1st seat)........................................................................................$ 30.00
    Cut for Add'l Seats (2-7) (Per Head)....................................................................$ 20.00
    Hone Guides (Ea).................................................................................................$ 2.00
    Install Guides (Ea)................................................................................................$ 5.00
    Mill Int. or Ex. Side (Per Surface).........................................................................$ 5.00
    Angle Mill Head Correct Int. Side & Ream Head Bolt Holes................................$200.00
    Clean Heads (Ea)................................................................................................$ 20.00
    Custom Machine Work (Hr).................................................................................$ 60.00
    Head Repair - Aluminum Heads.......................................................................Per Quote Gasket Match Intake Side (Pr)........................$125.00
    Gasket Match Exhaust Side (Pr)....................$125.00
    Bowl Blend (Pr)...............................................$150.00
    Polish Chambers (Pr).....................................$285.00
    Intake Match, Bowl Blend, Polish Chamber
    & Exhaust Port (Pr).........................................$650.00
    Full Competition Port & Polish (Pr)..............$1,100.00
    Port Welding to Reshape (Per Hr.)..................$ 80.00 Index Rods - Grind Mains.............................$100.00
    Polish Only....................................................$ 50.00
    Offset Grind for Stroker................................$250.00 Bore V-8 Block (up to .060).........................$120.00
    Pro Sportsman Hone (with plate)................$250.00
    Competition Hone (with plate).....................$350.00
    Finishing of Custom Unfinished
    Race Block..............................................Per Quote
    Align Hone...................................................$125.00
    Block True/Square Deck (up to .020).........$150.00
    Deck Heights over.020 Removed............By Quote
    Install 3 center 4 Bolts Caps.......................$350.00
    Install 5 Caps..............................................$500.00
    Sleeve Cylinder Bores (Ea).........................$ 60.00
    Install Cam Bearings...................................$ 30.00
    Machine / Align Bore for Big Ford
    Cam Bearings.............................................$600.00
    Big Ford Bearings.......................................$125.00
    Hone Small End to Float Pin (Ea)...............$ 5.00
    Hone Big End to Resize (Ea).................... .$ 6.00
    Rebuild Rods (Ea)......................................$ 10.00
    Replace & Hone Pin Bushings (Ea)...........$ 10.00
    Balancing V-8 Assemblies..........................$200.00
    (Heavy Metal to Balance Additional Time & Material)
    Balancing Flywheel & Pressure Plate.........$ 75.00
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    if that true whenever replacing main caps?
