Can anyone tell me where to find the pressure regulator?
Discussion in 'The Garage' started by LoggieStyle, Jul 21, 2003.
  1. LoggieStyle
    LoggieStyle Registered Member
    Jul 10, 2002
    78
    Tujunga, CA
    Hi,
    I am trying to install some fuel lines for the engine I am swapping in but I can't find the fuel pressure regulator. From the diagram in the book it looks like it is located on the rear drivers side of the engine but I don't see anything there that screams "regulator" at me. The engine is a 1999 454. If anyone has a picture of it or something similar, maybe a TBI/TPI 350/454 could you please post it? Or if you can describe where I can find this darn thing that would be helpful too.
    Thanks,
    Logan
  2. aj_johnson
    aj_johnson Registered Member
    Jul 20, 2003
    40
    have you tried following your fuel line from about the door on up?
  3. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    Sorry I forgot to mention it was going into my 75 blazer so following the fuel lines for the old 350 won't help me at this point. I believe they connect at different spots.
    Thanks,
    Logan
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The fuel pressure regulator is located in the throttle body itself in the rear.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    on TBI it is a gold can on the back of the TB, between the fuel lines....
    I don't know where it is on the Vortec MPFI...just follow the fuel line from the tank...usually on FI systems that are stock, the reg is in the TB or fuel rail itself...
    Chris
  6. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    I went out and checked it again, I think I found it but it was getting dark, I will check it again tomorrow.
