Can carrier be removed without removing pinion shaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Mar 2, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    Is there any way to remove the carrier without taking the pinion shaft out? can the c clips on the axles be removed any other way. I cant get the shaft out at all.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Nope. That pinion shaft is the only thing that keeps the axles from moving inwards and letting the C-clips fall off. /forums/images/graemlins/eek.gif Did the little bolt that holds the pinion shaft in the diff break off? If so, it IS possible to drill the bolt out, but it certainly isn't fun.
  3. zach78k5
    May 14, 2000
    406
    It broke off but i was able to drill a couple of holes in the carrier and make sure all the pieces came out. the shaft will turn with the spider gear when one wheel is on the ground. it just wont come out.
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Can you push or pull the axles at all or are they tight against the cross shaft?
  5. zach78k5
    May 14, 2000
    406
    there is a tiny bit of movement but not much.
  6. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    use a hammer and pound the pin in about 1/2 inch, then spin the carrier till the exposed pin comes up then just grap it with some pliars and yank like hell.
  7. zach78k5
    May 14, 2000
    406
    Problem. I cant get the pin to budge, I have been pounding on this thing since 10 this morning and it has not moved more than a couple of mm. I called NW differentials and am taking the rear end there in the morning. Hopefull they can fix it.
  8. 99firehawk
    Dec 15, 2002
    491
    I bet you could remove the c clips with a dremal.
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If the spider gears were loose, They may have hammered into the pin. Then it won't slide out. I had one that was SO bad, I used the torch and cut the carrier in half!!
