Can freon leak...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerWheels, Nov 30, 2003.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    slowly??? When the fan/anything blowing into cab I get a smokelike looking coming through the vent. It doesn't have any smell (it did give me a headache though)...When the truck is just running and no fan is on, the same smokelike stuff is coming out of the fan box under the hood. I am guessing it is freon, could it be something else????? /forums/images/graemlins/confused.gif
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    If it was freon the system would be empty in a few seconds with a leak that big. It could be a electrical problem like a burnt wire at the blower motor.
  3. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    It can be freon. I have seen an evaporator leak for a week like this. It's fairly common.
  4. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Agree on the evaporator leak Ive seen one leak for 2+ weeks Good luck
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    A good a/c shop, or repairman if you know one, could inject dye into your system to look for leaks. It is for use with a blacklight to spot freon leaks . It is generally inexpensive just to have them look. Then you could decide what to do . By all means this forums members are important so please find out what it is for your health, you said you got a headache from it.
  6. BlazerWheels
    Feb 13, 2003
    587
    California
    I figured it was from the evaporator...I will have someone check it out today. Had the windows down this morning and DAMN was it COLD!!!!!! And still got a headache!!! /forums/images/graemlins/shocked.gif
  7. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    It could be that resister for the fan speeds,Freon is oderless and would give you a lightheaded feeling..........
  8. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Resistor+ lint dust other assorted air polution will smoke and stink real bad.
  9. BlazerWheels
    Feb 13, 2003
    587
    California
    Mechanic looked at it today and told me it was the heater core...asked if the windows fogged up, asked if coolant level dropped...both yes. Found a VERY SMALL amount of coolant on passenger floor mat. Now I get to change that!!!! /forums/images/graemlins/grin.gif
  10. k5guyva
    Oct 26, 2003
    165
    Southeast VA
