can hubs warp?
Discussion in 'The Garage' started by jeff l, Jul 22, 2006.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    I put a new roter on my hub and my dail indicater reads a warp .
    not as bad with the old roter. I think the hub is warped. any input before I order a new hub.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Typically rotors need to be turned when first installed on our style of press on hubs.
  3. jeff l
    Jun 13, 2006
    104
    New Orleans
    thanks that makes sense
  4. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    I don't think that is at all necessary. They are "turned" when you get them and if they are "turned" off the hub you'll have the same result just thinner. Make sure the hub and rotor mounting faces are clean. If you had the ability to check the rotor for run-out then check the hub.
