Can I air down on an 8" rim and 12.5" tire??
Discussion in 'The Garage' started by stallion85, Apr 27, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Can I air down on an 8\" rim and 12.5\" tire??
    My friend said that he would not air down my tires with my setup do to the chance of losing a /forums/images/graemlins/dunno.gifseal. If I can air down what would be the lowest possible without any trouble
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Re: Can I air down on an 8\" rim and 12.5\" tire??
    I go gown to 15 PSI on my 12.50 33" 15" On 8" rims with no problems. I have ran a little lower PSI on snow only.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes you can air down. It is safer to air down your 8" rims then a 10" rim. There is more sidewall pressure keeping the tire on the 8" rim then a 10".
    Narrower rims are a poor mans beadlocks.
    Harley
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Harley
    That is what I thought, I guess he just didn't know any better. It kind of surprised me when he said that. Thanks for the quick replies /forums/images/graemlins/grin.gif
  5. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    My friend said that he would not air down my tires with my setup do to the chance of losing a seal. If I can air down what would be the lowest possible without any trouble
    As long as your rims arent 16.5" diameter (they have a different bead design and dont hold well at low pressure).....like Harley said the 8" rim actually holds a bead on a 12.5" wide tire very well /forums/images/graemlins/thumb.gif
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I concur with everyone else, AIR EM DOWN. I run stock ralleys and have run white spokes, both 15x8. I take em down to 20 most of the time, could go lower but it works well as is. /forums/images/graemlins/k5.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i ran my 8in wide rims and 12.5in tires down to 8 psi in the sand and 12 on the trail and never blew a bead /forums/images/graemlins/thumb.gif
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I run 8" wheels on 37-1250's and no problems yet at 10psi or so. I have reverse wheels which are the real poor mans beadlock.
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I run the stock rallies(7"?) with 10.50s and I go down to 12 PSI...
  10. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i run the 8" wheel and with my 36/12.50s i would air down to 8ish regularly....went to 6 in the snow and popped a bead winching myself sideways....
