Can I bolt up an 81+ bumper to a 73-80 truck?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dremu, May 25, 2004.
  1. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    I know the trim is different, but will a later-model bumper bolt up to an earlier truck, i.e. is the hole pattern the same? (My trucks and my parts are not in the same place, or I'd look myself /forums/images/graemlins/smile.gif)
    -- A
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the frame horns are different,
    the 81 and up is like C channel cut on a angle, the bumper bolts to the brackets, and the brackets bolt to the frame
    the 73-80 the frame is rounded in the front and the bumper bolts directly to the frame, no brackets.
    i think they might bolt up but not sure, never tryed to put one on the other /forums/images/graemlins/dunno.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You could probably do it, but you'd have to cut the frame rails.
  4. dyeager535
    26,979
    Bolt pattern for the bumper is different, but can't recall if thats only on the front or not.
    I believe the 81+ bumpers front and rear have each pair of bolts on each side inline vertically, whereas at least the fronts of the previous trucks have them offset.
  5. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I put bumpers from my old '75 onto my '84. I had to use spacers on the bottom center set of bolts and the bottom bolts on the outer set didn't line up at all. Same story front and back.
    This is the opposite of what you're looking to do, but maybe it will help.
