can i change just the wiper arm posts ??
Discussion in 'The Garage' started by boggerless, Feb 22, 2004.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    my truck was a 79 and i got a 86 cab.i threw out my old stuff.and i used the old hood . now it doesn't shut on the drivers side.i need shorter posts. can i get just change those? thanks /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I had to replace the posts on my pickup, it was a ten minute job. It is easy to do. If the current ones are too high, try something from a junk yard - I paid 10 bucks for mine.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Yes you can. The bolt that holds the pivots are different. Newer style uses 3, older used 2 bolts per pivot. The bolts on the passenger side of each post will line up, You will just have to drill 2 new holes for the other bolts.
  4. boggerless
    May 26, 2003
    22,728
    96
    thanks bro, maybe i'll check lmc if i can't find any in a junk yard. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  5. boggerless
    May 26, 2003
    22,728
    96
    thanks bro, i'll find e'm , i hope. /forums/images/graemlins/smile.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  6. playtoy1
    playtoy1 Registered Member
    Nov 25, 2003
    41
    central michigan
    daryl when you come get that one ton i have a bunch of them you can have let me know
  7. boggerless
    May 26, 2003
    22,728
    96
    you got it herb, thanks /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
