can i change these my self or....
Discussion in 'The Garage' started by down4thakrown, Dec 12, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    should i leave it up i to a shop?????
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    balljoints?
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Ya, what exactly do you need to do? Also, just curious, is that a D44 or a 10 bolt?
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    There should not be anything inside the lower hole. The upper one is the balljoint preload nut. It is a very important part in keeping balljoints happy. Are you replacing the balljoints?
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i know how to do the ball joints im just want to know if that top bushing piece thats, threaded & pronged and the bottom bushing thats pressed in, require and special tools. D44 it is
  6. divorced
    Jul 20, 2004
    5,115
    The bottom one should just be a hole without any bushing. The top sleeve uses a special 4 prong socket. I bought mine at Napa.
  7. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    oh, must be wear from the knuckle. it looks like there's a busshing pressed into it. i guessin the tool at napa is around 5$ hopefully.....what should i tightin the ball joints down too in ft lbs? thx
  8. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    Bought my socket for $21 from snap-on. Prior to that I made one from a 3/4" socket and grinder. The threaded bushing should come with the upper ball joint.
  9. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    what is that tool for the bushing called???i went to napa and carquest and they dont carry it and theres no listing for it.
  10. divorced
    Jul 20, 2004
    5,115
    I bought mine at Napa, it was about 20 bux. I can't remember the name of it. The guy found it in a big tool catalog, about 2" thick.
  11. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
  12. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    ive called 3 napa's and 2 carquest's and went to the dealer ship. and no ones has this. dealership said they'd have to order it. :mad: :mad: think im just goin to order the snap on one.
  13. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    tool
    GM number is J-23447 for 10B, don't know if D44 is the same. I surfed for my J-23447, don't rem who I bought from. @$15.
    Edit; or OTC-7050, IIRC OTC is Otawanda Tool Corp.
  14. mechted
    Oct 19, 2003
    765
    Granbury, TX
    If you can find a truck and tail him till he stops its probably faster... dont know how urgent the repair is
