Can I connect a 4" bathroom fan duct to my 4" dryer duct with a "Y"?
Discussion in 'The Lounge' started by Jessie James, Aug 26, 2012.
  1. Jessie James
    Jessie James 1/2 ton status
    Oct 16, 2009
    2,515
    VA
    I am installing an in-wall bathroom fan and it happens to be sharing a wall with my utility room where my washer/electric dryer are located. It would be incredibly simple to buy a 4"x4"x4" "Y" adapter and hook the bathroom fan duct into the "Y" and then also connect the duct for the dryer into the "Y", and then use the existing duct out the side of my house, instead of running a second duct through the side of my house.
    I am thinking I would put a backdraft vent on each line before the "Y" so the fan wouldn't blow into the dryer and vice versa.
    Is there any downside to this? Fire hazard? Death and destruction?
  2. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    690
    5
    west central illinois
    A 4" vent can't flow enough air to let the bath fan work with the dryer running. I would probably run a separate vent.
  3. Jessie James
    Oct 16, 2009
    2,515
    VA
    That is what I was afraid of. Thanks for the feedback!
  4. scotto0609
    scotto0609 1/2 ton status Premium Member
    Feb 3, 2004
    1,524
    3
    babylon,ny
    I cant recall the size of my bathroom duct but it is tied into my dryer vent and works just fine.
  5. sweetk30
    Nov 1, 2004
    24,876
    168
    horseheads , ny 14845
    prob against code also to share.
  6. Jessie James
    Oct 16, 2009
    2,515
    VA
    That was my other concern.
    I'm debating putting it in the ceiling now and out through the side of the house. A lot more work, but would look a lot nicer.
  7. k5warwagon
    k5warwagon 1/2 ton status
    Feb 25, 2009
    419
    Middleburg, NC
    It's against North Carolina code I know. Also, depending on the length of run to the wall vent and length from y-fitting to the bathroom fan, you could have hot dryer exhaust coming back in your bathroom. Even with a directional flow Y. It's all depends on friction loss of each run.
  8. Massacre-77
    Massacre-77 1/2 ton status Premium Member
    Nov 8, 2008
    123
    portland or
    i would not do this some lint and hot air will be blown in the bathroom.
  9. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,255
    3
    Tri-Valley, NorCal
    Or conversely the foul stench of a nice deuce could make its way into your dryer. You might end up using 5 Bounce sheets per load just to keep the beer and chili smell from your clothes....:eek1:
