Can I convert from auto to manual?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83DK5, Apr 13, 2000.
  1. 83DK5
    83DK5 Registered Member
    Mar 13, 2000
    19
    Kansas North East
    I am currently running a th400 and it just went dead. in an 83 with the 6.2 deisel. My main concern is the length. Will I have to get a longer or shorter driveshafts? The th400 that is in it is not the original Tranny. It originally had a 700. I am planning on a sm 465 or nv4500. Any help in doing this conversion is most welcome.
    Blazers Rule especially Diesels
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I've never seen an auto to manual swap, but i have heard of a few so it's possible. You'll really want the NV4500. What kind of clutch are you using? Hydrolic would be easier to set up and won't move when the tub moves against the frame. If you go with a linkage style, you need the bracket on the driver's side framerail next to the motor, and all the clutch link components. You'll also need an adapter for the T-case whether you choose the NV4500 or the SM465. You will also need a flywheel. as for the driveshaft, you would need a longer front one because the manuals are shorter then the automatics. The rear shaft can be shortened. Where did you find an NV4500? They're hard to find used.</font color=blue>
  3. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    i have an SM465 and 205 t-case that i need to get rid of. it came out of a '79 K5 and it worked perfect... i even think that i have the drive shafts
    NEVER been stuck... *yet*
  4. 83DK5
    Mar 13, 2000
    19
    Kansas North East
    Hmm anybody know if this will bolt up to the 6.2 deisel.?
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Advance Adapters has adapters to put together almost any engine-tranny combo.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  6. Truckfan2
    Apr 10, 2000
    343
    Northern IL
    i think that the bell housings are the same. hmmmmmm....
