Can I cut the motor mount a bit so I can drain the block.....
Discussion in '1982-Present GM Diesel' started by 84CUCV, Dec 24, 2002.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    If I can I was going to run a pressure hose to clean the block a little more. Good idea or not? Thanks Mike
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I haven't looked at it to check, but I can tell you if you are not removing much then it should be OK.
    If you are removing more than 1/2" then I would recommend you weld in some reinforcement to keep the braket in shape.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK..... Still not sure what to do. mike
