Can I disable my truck by pulling a fuse or something?
Discussion in 'The Garage' started by Scott A, Nov 5, 2003.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    I don't have an alarm on my 83 Blazer 6.2L Diesel. Is there a fuse or anything I can dissconnect to prevent someone taking my rig/forums/images/graemlins/k5.gif?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Leave a coil wire on the seat when you park it. /forums/images/graemlins/rotfl.gif Thief will never be able to figure out where that goes.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Leave the coil wire on the seat when you park it
    Sence when do diesels have coil wires?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    thats the point, thief will pop the hood and try to figure out where to put the wire /forums/images/graemlins/smile.gif
  5. I don't know if your year has these fuses, but I always pull the ECM and crank fuses on my 89 whenever I park in a questionable neighborhood.
  6. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I dont know about a fuse (there might be im not framilar with gm diesels) but you can pull the wire on the injection pump (fuel shutoff solenoid).
  7. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    wire funny /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    i had a civic that sat for a while so i pullled the main fuse out of it, some prick actually broke into it, busted the steering column and thats about it.
    anything vital will do, fuel pump, main fuse, injector fuse whatever makes the thing not run (pull the fuse, crank it and see if you can drive away) if they can't get it going quick they will leave it.
  8. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    take your tcase shifter off, cut the shaft about half an inch below where it goes through ur rigs floor... then thread the end of the top half of the shifter... weld a piece of threaded tube to the bottom of the shifter. Now, when u are going to leave ur rig sitting, shift your tcase into neutral, twist off your shifter and take it inside ur house with you. If you ever hear your rig hit 5k rpm outside ur house, grab ur 12ga and go investigate. /forums/images/graemlins/grin.gif
    j
  9. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    That is actually a pretty cool idea.
    Why don't you just wire up an emergency shutoff switch and hide it?
    -Andrew /forums/images/graemlins/usaflag.gif
  10. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    no anti-theft device is 100% effective.. I think it takes a whole system of devices for the best protection. The removable tcase handle is 1 part... a good hidden kill switch is another.
    now that I think about it tho... the top part of the shifter should be the part that has the threaded sleeve welded onto it... because otherwise in theory a guy could just put a big screwdriver in the sleeve and shift it that way. With the bottom part being the threaded shaft, that wouldnt be possible... and so long as its below the body you couldnt get a grip with pliers on the nub either. I dunno about other peeps, but you aint shiftin my np205 without the leverage from a tcase shifter. /forums/images/graemlins/grin.gif
    j
  11. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    If it goes below the body of the truck, you could install a locking plate to cover the hole so you couldn't even get to the lever in the first place.
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Uh...I get it...I guess the jokes on me /forums/images/graemlins/rolleyes.gif
  13. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yep, good point! this could be a great way to conceal your anti theft device as well... if the cover/lock was low key enough and painted/coated to match the rest of your interior a thief might not even see it in the dark. if he knew chit about trucks, he'd prolly just figure it was a 2wd rig... and when it wouldnt move that it was busted! lol! if he didnt know trucks... well... he'd prolly still think it was busted. either way your neighbor is getting ripped off instead. /forums/images/graemlins/wink.gif
    j
  14. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I spliced into the injector pump solenoid wiring and then installed a switch under the dash. With the switch off the engine will crank but won't fire. I like this idea the best because the thief will most likely just think the engine is hard to start.....if everything is dead than it's pretty obvious there is a kill switch which they might start lookin for.
  15. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    MSD boxes have an extra wire (white I believe) that can be hooked up to a switch (to ground) that will kill spark from the box.
    If you already have an MSD box.....it's a quick and dirty 1st step.
  16. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I know I can shift my 208 from underneath the truck, so if a thief could figure out what was going on, he would just have to jump under the truck and shove the shift linkage back to 2H.
  17. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yet another reason not to own a np208. lol!!! no way my 205 is shiftin without a lever of some kind.
    j
  18. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    First battery kill switch under the hood...
    Next, starter interupt switch located (uhh for fun let say, on a plate mounted above the ashtray behind the dash.. flip the ashtray down and reach up)
    Next some form of Brake lock, like The CLUB II thingy
    If your paranoid make it go under the brake and gas pedals (assuming you build your own)
    Lastly, park under a light or motion detecter light
    If you need more than that, MOVE to a new area /forums/images/graemlins/tongue.gif
  19. clubba68
    Dec 6, 2002
    1,511
    My switch still allows the truck to try to turn, but won't.
  20. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    The good ol' "better you than me"/forums/images/graemlins/thumb.gif
    Yeah, I have a cut of switch to the pump hidden....they can sit there and crank it over all day...the biatch aint gonna start. Might fire and burn whatever is in the line, but thats it...then it shuts off and isnt gonna start back up.
