Can I do this with my drums?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Mar 26, 2003.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I bought some new drums oday because my other ones had grooves in them and were toast. Heres my quesion can I install these new drums without changing the brake pads the pads are in good shape.
    Or will it just make grooves in my drums again?
    /forums/images/graemlins/usaflag.gif
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    do your brake shoes have grooves or peaks on them? if they have any high peaks on them they might not grab too well until they get worn down even again. me personally, i would just go ahead and replace the shoes while you've got it apart, especially if they are uneven. you can get new brake shoes for about $20 - $25 at most parts stores.
  3. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    If your hard for cash, you can getaway with using the old ones if they have enough pad left (more then 1/8 inch thick) only because they are your rear brakes which don't do all the braking. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  4. dyeager535
    26,982
    191
    This may sound silly, but if your truck has bonded shoes on it now (not riveted) I would *seriously* consider replacing them.
    Friend just got through with this issue, once again the lining seperated from the steel, and wedged into mechanism, making for "interesting" stops. I've seen it on more than one occasion, seems like any time the drum is removed, the "breathing room" afforded the bonded shoes encourages them to fall apart.
