Can I drill and tap this???
Discussion in 'The Garage' started by RingMaster4x4, Jan 5, 2005.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I have a NP205 t-case that I need to drill and tap the side of the case so I can put the brace that holds it the frame on. Is this something I can do or do I need to have a shop do it? Or do I just need to trade it for one with the holes?
  2. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
  3. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I wouldn't drill and tap the side of the case. It is made of cast iron and is strong, but its not the thickest on the side and your not going to get many threads out of it. What drivetrain are you running? Do you absolutly need this? If you are set on using a brace, I would go to an existing bolt before bothering to drill and tap the case, maybe to one of the front output rear cover bolts.
  4. sublmnl1990
    sublmnl1990 1/2 ton status
    Nov 8, 2004
    419
    Virginia Beach Va.
    Get your grove on!!!!
    yes you can drill and tap this baby...
    :haha: :haha:
    sorry bro couldn't resist
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    If the pad is there you can drill and tap the holes. (some cases are drilled and tapped some are not. I've seen them drilled but not tapped too)
    If you have a good 1/2" drill and good bits and have a 5/8" tap.
    and a way to secure it so you are not chasing it all over the shop trying to drill the holes have at it.
    Drill and tap about 5/8" or so and use a stud kit.
  6. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Let me post some pictures. I am not really trying to drill right in the side. There a raised thinker spot that in the T-case that came out of me blazer had two 5/8" holes drilled in it for this mount.
  7. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    :eek: :rotfl: :haha: I had a feeling I was going to get this.
  8. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Good god, a guy would need quite a big drill to tap that!:haha:
