Can i fit 33" tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89K5mudder, Jul 4, 2003.
  1. 89K5mudder
    89K5mudder Registered Member
    Apr 18, 2003
    20
    Random Lake, Wisconsin (Near Sheboygan)
    Can i fit 33\" tires
    I have a stock 89 blazer, can i fit 33" tires on with it being all stock.
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Re: Can i fit 33\" tires
    I believe you can. They may rub some with the steering wheel fully turned, and going over a big bump, but they should be ok. My friend had 33's on his stock 85 K5 and they fit fine.
    -Harrison
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the answer is yes. with the correct offset wheel you can minimize rubbing at flex...
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Read this............ /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif
    33" tires on stock suspension.
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    When I was running 33's I had to cut my front fenders both front and back to not rub, even for street driving. If you don't want to lift it or use the sawzall I would suggest 32x11.50s.
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    What width were your wheels?
  7. GQ 350
    GQ 350 Registered Member
    Jul 20, 2002
    19
    Kelowna, British Columbia Canada
    I have seen as big as 35"s on a stock truck with some rubbing, on the street but alot more off-road but sill drivable. However I have only seen it on the 81 to 87 body style for trucks and 81-91 for K5's, and I know that on my 80 body style it seems to have less room in the front wheel wells. I'm not sure but it almost seems like the newer (81-91) body style has a bit bigger wheel well on it. But I am not 100% sure but I know that for moderate off-roading I have seen 35"s run on the stock height but only in your body style (81-91)
    I hope this helps you out a bit. /forums/images/graemlins/truck.gif /forums/images/graemlins/pimp1.gif
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. GQ 350
    Jul 20, 2002
    19
    Nice rig it looks great. /forums/images/graemlins/truck.gif /forums/images/graemlins/pimp1.gif
  10. Hustler
    Hustler 1/2 ton status
    May 14, 2001
    326
    St. Peters, MO
    I have a 90 with 33" on 15x10 wheels and they fit fine. I even have gone off road once with them and they did great. I did rub once with no damage.
    I would say if your springs are good, then they will fit, if your springs a sagging some, then they might not fit.
  11. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    8" rims are better. I could go just about anywhere I wanted and I would crash the fronts on occasion, but once did I rub out back.
  12. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    I'm running a set of BFG 33x10.50 on stock alloy wheels and they fit just fine. They haven't rubbed even on some fairly challanging trails. The only drawback is that they look a little skinny on something as big as a K5.
  13. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Ya need 12.50's /forums/images/graemlins/thumb.gif
  14. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
  15. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    12.50 33s on stock suspention. They dont rub on mine.
    However I did trim a little off the corner of the inside of the very rear of the front front fenders just to be sure.
    They are mounted on 8" wheels with 4" backspacing.
    FYI.12.50sx33" in most cases usually will rub when mounted on 10" wheels on stock suspention.
  16. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I should get off my lazy can and go get the pics developed of me and the 35's up on the RTI ramp /forums/images/graemlins/rotfl.gif
  17. 89K5mudder
    Apr 18, 2003
    20
    How are the springs on yours. Are they saging.
  18. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    No sag but i Forgot to add that I have add a leafs in the rear because I tow a lot.
  19. bajaviking
    Apr 10, 2002
    752
    Baja
    "What width were your wheels? "
    I was running 10" wheels.
  20. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    8" wheels.....
