Can I fit 35s without cutting??
Discussion in 'The Garage' started by PhoenixZorn, Apr 26, 2005.
  1. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    If I put a 4 inch lift on my truck, can I stuff 35s under there without cutting my fenders? I read in Four Wheeler mag that it requires slight trimming... but I'd rather not cut anything.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you may have to trim just the back corner of the fender when at full lock.
    i have very little back spacing on 10" wide wheels and i had to trim just a bit off the back bottom corner.
  3. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    I have this combo and it only hits at full lock when going over a bump/flexing. It still doesn;t hit badly enough to worry about it. I will cut an inch or 2 when I get around to it.
  4. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I have a 4" lift + ORD zero rate for extra 1". although it hasn't rubbed yet, I have flexed it out completely to make sure.
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I ran this for a year or so and same thing, only at full lock and on a slight grade of some sort. Rubbed enough to rip the molding off of the edge but no biggey. I wanted it off anyways.
  6. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    if u run 8" rims instead of 10" with the same backspacing, 4" or so, it will clear alot easier.
  7. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    I have 35s on mine with only a 2" add-a-leaf in the front and a 2.5" ORD flip in the rear. It rubs occassionally but not bad at all. You should be fine, but that all depends on the actuall size of your tire and the wheel backspacing/width. I have 10" wide that are damn near centerline, my tire measures to be 34 and 3/4 so it's almost a true 35.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I only have 33's , and I just almost hit the edge . I can hit the inner fender when straight and stuffed :D
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run 35" MTR's (33.5" true height) with 4" or slightly more front lift. I run 15x8" rims with 4" BS and I rub the sh*t out of my inner fenders when wheeling and I had to cut alot to get the tires to clear the fender lips.
    Harley
  10. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    with my blazer(6" lift, stock shackles, 15x10 rockcrawlers 3-4" back spacing, 35x12.50 marshal power guards, no sway bar) I rubed the back of the fenders pretty good. had to cut 2" off and still was pretty close looking.
  11. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Yes you should be able to.
    I run 35X14's on 3"bs. 10" wide rims
    About 2" off the back of the front fender and a little beating of the front to roll the sharp edges away from the tire.
    This is on a stock truck , no lift.
    Just try them out , if no lift and trim fits , 4" lift without trim may :grin:
    Each rig is different with what you can get away with :dunno:
  12. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I'm running BFG AT 35's with 5" of lift and have had no problems at all. If you need another inch, get a set of zero rates, that's what I did in the rear and they work great.
