can i fit 35's?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by silver, Aug 20, 2002.
  1. silver
    silver Registered Member
    Jun 8, 2002
    72
    Dallas Texas
    can i fit 35\'s?
    i have a 1970 blazer with a 4" suspension lift and i'm looking into a 2" leaf spring lift... if i added that would i be able to fit 35's? I DON'T WANT TO CUT ANYTHING. any help would be appreciated
  2. Tonka
    Tonka Registered Member
    Jan 28, 2001
    30
    Fort Worth TX
    Re: can i fit 35\'s?
    Hey, I'm from Dallas too. If you already have a 4" suspension lift then it must be springs unless you are using blocks in the front (which you shouldn't). Here is what I am doing with my 72. I presently have two inch springs all around and I run 35s on the street with no problem. I wouldn't want to get it all twisted up off road but it works with minimal rubbing and no cutting. I am in the process of changing the front springs to 4" softrides and adding two inch blocks to the rear softride 2" springs. I expect this will work ok for what I do. (I go pretty easy on my truck) If you really want to off road, I expect most will tell you to go with at least 6" of lift to run 35s. Where in Dallas are you? Would be cool to go have a beer at strokers sometime.
  3. swamp donkey
    swamp donkey 1/2 ton status
    Apr 29, 2002
    186
    Thousand Oaks, CA
    I have a 69 w/ 4" lift and 35's. Works fine for street and mild offroad. Rubs a bit if you turn REAL tight (full lock).
    You can see pics at: My Blazer
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Very Nice Rig! I Like! /forums/images/icons/cool.gif
  5. jjtwuk
    jjtwuk Registered Member
    Jul 30, 2002
    11
    Windham, Maine
    great looking truck - good job /forums/images/icons/cool.gif . I really like the paint and the rollbar. How do I get a hold of GM Truck Center to get one made for me.
  6. swamp donkey
    Apr 29, 2002
    186
    Thousand Oaks, CA
    Henrik is the owner. They are in Burbank. Make sure you tell them Dylan sent you.
    There web site is GMtruckcenter.com
  7. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    How wide are your wheels and how much backspacing do they have?
  8. swamp donkey
    Apr 29, 2002
    186
    Thousand Oaks, CA
    10" rims with 35" x 12.5" tires. Standard backspacing.
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Just tried the first fitting of my new wheels/ tires 37/13x16 boggers on 16x8 Champion beadlocks. /forums/images/icons/grin.gif [​IMG]
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    my 72 gas only 4 inch lift and 35x12,5r15's.i jhave no trouble off road and get full stuff with the 35's with no rubbing.also 4 inch backspace 15x8 amercan racing rims
  11. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    my 72 has only 4 inch lift and 35x12.5r15's.i have no trouble off road and get full stuff with the 35's with no rubbing.also 4 inch backspace 15x8 amercan racing rims
  12. silver
    Jun 8, 2002
    72
    Dallas Texas
    haha, i'de love to have a beer with you, but you're buyin cuz i'm only 16. i'm near the park cities. what color is your blazer? i've only seen one other 1st gen. around here and it's orange... mines silver.
  13. Tonka
    Jan 28, 2001
    30
    Fort Worth TX
    Park Cities? Guess I'm not familiar with that. My Blazer is green and I live in the Mid Cities area (Hurst Euless Bedford) 16? You got a cool first ride.
  14. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    You guys think I could run 35's?
  15. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    you should be able to run 35's with 4".
  16. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Time to move that rear axle back about 1.5" methinks....! /forums/images/icons/grin.gif
    I still can't believe that I stuffed 38.5" under the rear fenders without trimming the stock openings!!! I really need to see some photos of it flexing to figure out how it worked.
    1.5" rear wheel spacers on my 14BFF were a big help too. Never touched the inner wheel tub.
  17. aksidentproan
    Dec 8, 2001
    477
    Maryland
    I have the u-bolt plates that allow me to move it back one inch so that will have to be enough. I just have to get out there and do it.
    Evan
  18. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Evan,
    You'll be amazed at what it takes to keep the fronts from rubbing! I moved the axle forward 1" and it looked like the tires were going to rub all over the bumper-side of the opening. In reality they STILL rubbed on the footwell side....
    Making the front fenders "look stock" but actually still clear the 38's is going to be a challenge. /forums/images/icons/shocked.gif In the rear, moving back even 1" should give you surprising amounts of clearance. All the Blazers I've ever seen have that rear axle VERY close to the front edge of the fender, and that's always where they'll rub first.
    Wheel spacers (or a van-width 14BFF) is another key to getting clearance in the back. The nice thing about it is you get the same track width on the front and rear axles, and it looks REALLY good that way.....plus no rubbing on the wheel tubs.
    One of these days I'll have to get my finished truck on a ramp and snap a few detail pics of how it stuffs. /forums/images/icons/cool.gif
  19. silver
    Jun 8, 2002
    72
    Dallas Texas
    what is 14BFF? is it something relating to a 14 bolt differential? (i'm a dumb ass about all this stuff and i'm trying to learn not to be)
    grant
  20. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Grant,
    Don't sweat it.....it's just short hand. 14BFF = 14 Bolt Full Floater, 14BSF = 14 Bolt Semi Floater.
    Both are GM corporate 1-Ton rear axles. The full-floater is considered to be more beefy than the semi floater, and if you ever broke an axle, you could still drive it home.....
    If a semi floater breaks, the broken axle and the wheel fall out of the axle tube.....and you're screwed! /forums/images/icons/shocked.gif
    Most folks here consider the 14BFF to be the ultimate, cost-effective upgrade for the K5. They are plentiful and cheap and you can put Detroit Lockers in them for cheap....
    Hope that helps clear things up a little. /forums/images/icons/smile.gif
