Can I fit 40" tires on my truck????
Discussion in 'The Garage' started by 80blackgmc, Apr 11, 2005.
  1. 80blackgmc
    80blackgmc Registered Member
    Nov 21, 2004
    43
    Hey guys. I have an '80 GMC with 4" suspention and 3" body lift, with bushwaker fender flares. The truck came with worn 38.5" superswampers, and they fit fine. Right now it has 35" procomps on it, that look a little small for the truck.
    I'd like to upgrade my wheel/tire combo to the maximum size I can run on this truck. I like the idea of a 40" goodyear MTR on 17" wheels, but will that fit my truck?
    Any other tiresize/wheel size combos that would work. Remember, I want it to be the tallest possible and still keep a "street" tire. I don't do a lot off offroad, but I do some. Mostly the truck is for towing.
    If I can't fit the 40s on there, what would i have to change on the truck to make it work?
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Short answer: possibly
    Long answer: if you're pulling with a K5, I really don't think you want to be running 40" tires unless you have 5.13's in there or one hell of a stout engine. And I'm not sure the tire/wheel combo would fit. I hacked my fenders and relocated my front axle to make 39.5" boggers fit on a 6" lift. Somebody around here has probably done it, just give it time.
  3. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I have 39.5s with 2" add aleafs and a 3" body lift , it all depends on if your willing to cut.
  4. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    just :hack: :hack: :hack: till they fit :D
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am shoving 40" MTR's under my fenders with only 4" of lift. I won't even have to trim. I do need to move the axle foward an inch though to clear the floorboard/firewall.
  6. 80blackgmc
    Nov 21, 2004
    43
    It has 4.56 gears and is getting a decent 454 (almost done).
    Like I said, it already has big fender flares (with obviously cut fenders), so I don't see the need to cut. I could be wrong. 38s would "do", but I want that look. :)
    Anyone with 38" or 40" tires and some pics??? Thanks.
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    One thing to remember the narrower tires (MTRs) will fit better than boggers, I trimmed one of my old blazers to fit 36s and I am convinced you could run 38x12.5s on a stock rim with no lift WITHOUT moving the axle forward but the cutting involved would be quite complex.
  8. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    My 75 came w/ 6" lift and 38.5" swampers. unfortunately I had to put a set of 35" radials on it for the 1500 mile trip home. When I get another pair of 38.5's I will try to get a pick for you if you still need it. I am looking at getting a pair of boggers for the rear and use two sx swampers in front as 2 are balder than heck atm. But they fit in there fine. I am sure 40's will fit in yours well also. You have 1" more lift than I and most likely more cutout on your wheel wells. Hope this helps somewhat :waytogo:
  9. 80blackgmc
    Nov 21, 2004
    43
    Thanks. There is nothing like a test fit.....
  10. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Here are some pics of my old k5 with 5" lift and 39.5 boggers.
    Specs:
    4" Front springs, 1" ORD zero-rate axle moved 1.5" forward
    Stock rear springs echobit shackle flip with a 1" homemade zerorate
    Lots of trimming
