can i get 37x13.50 with 6" lift?
Discussion in 'The Garage' started by dodgetruck91, Sep 25, 2003.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    can i get 37x13.50 with 6\" lift?
    hey, im looking at somoe explorer pro comp 37x13.50 for my truck, can i get away with my 6" lift? or will i need another 2" of body? also, anyonoe use these tires before? thanks
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: can i get 37x13.50 with 6\" lift?
    It's possible it will work. Depends on the backspacing of the rim, but you'll most likely have troubles with them hitting the fenders when turning. That's a fair amount of width. Taking a little bit off the front fender would be a better option, in my opinion, than a bodylift.
    What Pro-comps, the MT's or the X-terrain. ( /forums/images/graemlins/thinking.gif Must be X-terrain, I don't think they make the MT in a 37, do they?)
  3. dodgetruck91
    Oct 22, 2002
    99
    thanks a lot!, where at in delafield are u, im in new berlin and am in delafield a lot. thanks, jon
  4. heavy4x4
    Aug 28, 2002
    3,270
    I knew you were in S.E. Wisconsin, but not sure where.
    My house is in Delafield by the Hwy 83 - I94 intersection. BUT, I'm only there in the summers and holiday breaks now because I'm at the University of WI - Madison.
    I'll be home the weekend of Oct 3-5 swapping front axles if you want to lend a hand /forums/images/graemlins/wink.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/rotfl.gif
  5. heavy4x4
    Aug 28, 2002
    3,270
    Here's the list of WI members I've compiled:
    heavy4x4 (Delafield, WI)
    Polaris (Rhinelander, WI)
    SS66 (Oconomowoc, WI)
    rugger03 (S.E. WI)
    nofeartruckin00 (New Berlin, WI)
    woody9 (Warren, WI)
    77k5bogger (Winneconne, WI)
    dodgetruck91 (New Berlin, WI)
    Nikk (Lacrosse, WI)
    Fletch79 (southern WI)
    89K5mudder (Random Lake, WI – Sheboygan)
    outsider223 (Gillett, WI – Green Bay)
    crazykev4x4 (WI)
    bigwishlist (Sheboygan, WI)
    87roadwhale (north-central WI)
    chosen1 (Cudahy, WI)
    bigoltrux77 (Milwaukee, WI)
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have lots of clearence with 35's and 9" lift [​IMG]
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    They would probably fit if you cut the fenders otherwise the extra 2" will be needed.
  8. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i got 37x12.5's and 4 1/2 BS no rubbin on streets, yet to flex out though. No trimming either
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Considering I cut my tires up pretty good with 4" and 35s, I'm inclined to say you've never even hit a speed bump too hard.
  10. jekbrown
    May 19, 2001
    45,029
    361
    Vancouver, WA, USA
    37s? 6" of lift? trim them fenders, them suckers will fit no problem. My 39.5s fit on 5" of lift with trimming. /forums/images/graemlins/grin.gif
    j
  11. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    You can fit 37's on a 4" lift, but you will rub the firewall up front with soft springs.
  12. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i've hit speed bumps kinda hard.. no problems, i'm gonna try and flex out this weekend and take pics
  13. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have 37x12.5's on 3" of lift. They are not close to hitting the firewall when flexed. Just trim the fenders and you will be fine.
  14. zcarczar
    Feb 10, 2002
    2,495
    Hmm, I'm running 36's on 4" of lift with the fenders trimmed all the way back to the firewall and I can rub the firewall on full bump with the wheel's turned. /forums/images/graemlins/thinking.gif
  15. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I am running the 37x12.5's w/6" of lift and the fender trimmed back to the inner fenderwell and don't have any rubbing problems; however, I can stuff a rear far enough to rub the fenderwell in the rear above the floor line.
