Can I install a 4' lift without having to change any other parts
Discussion in 'The Garage' started by MEGALADON, Feb 8, 2005.
  1. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    LIke would I have to get different shocks?
    drive shaft angle? different pitman arm?
    Are these kits true bolt on's without
    other mods.:) having to be made
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no one claims they are and they aren't. You need new shocks, steering arm(not pitman arm), and maybe brakelines.
  3. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    And where do I find those parts?
    from the company that sell's the lift kit.
    or does someone sell the complete kit.
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well a 4' lift is pretty big.....( ' = foot ... " =inch)
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    please give us the info on your truck to answer this correctly. and yes it can all be goten from 1 supplyer ( springs frt , blocks rear, or springs rear, arm, shocks, ubolts and drop sway bar brackets) thay should have a brake line kit to sell also.
  6. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    LOL, I guess that would help:grin:
    all stock for now 82 gmc
  7. sweetk30
    Nov 1, 2004
    25,526
    526
    nice truck. i would go 4" frt springs and if street driver drop brackets for the sway bar ( about 70% of us remove that item) or remove alltogether. then new shocks all 4. if you want it to ride real smooth then get 4" rear shackel flip for rear . it makes it so no blocks or spring change or ubolt removal, just rear hanger change. this combo will alow 35" tires ok with slight fender contact if swaybar left on, if off fender trimming required . 33" tires no problems.
    i did the swaybar off and flip kit on my truck and the flip was 200% better ride in rear.
  8. sweetk30
    Nov 1, 2004
    25,526
    526
    here is 2 pics of the flip kits offered on here in the vendor form.the painted 1 is offroaddesign item
    the non painted one is sky manufacturing kit
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    On a 4" lift I prefer to use a drop pitman arm instead of a raised steering arm to avoid bumpsteer.
  10. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I may be wrong but doesn't a drop pittman arm cause more stress on the frame where the steering box mounts? I know we have enough problems with frame cracks there.
  11. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    isn't bumbsteer only a problem for ifs rigs?
  12. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    how much is a flip kit for a 6" superlift?
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Uh, no. Bumpsteer affects all rigs with mechanical steering.
    Not really. The bolt on brace is an absolute necessity anyway, but the pitman arm isn't really causing additional stress. That area of the frame is just weak.
  14. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I've alway heard of bumpsteer being referred to as how the camber and toe is affected as the suspension compresses.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is more camber change with our suspensions than with IFS.
    Bumpsteer in our case is due to the axle moving farther from the frame, and the drag link being one solid piece, it can't change lengths.
  16. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
  17. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    Been there done that and I too recommend a drop pitman arm for a 4" lift.
  18. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    THANKS SWEET, Since i am not a member, I am not allowed to
    PM, or see any pic's like that. can you e-mail it to me please :)
    SSL88@aol.com
  19. divorced
    Jul 20, 2004
    5,115
  20. sweetk30
    Nov 1, 2004
    25,526
    526
    thay are in your email box . good luck budddy
