Can i just order the triple shifter boot?
Discussion in 'OffRoad Design' started by highrider_44s, Apr 20, 2005.
  1. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    I was wandering if I could order just the shifter boot that you have for the triple shifter setup. If i can whats the going price and is it predrilled for a specific bolt pattern. I had the 208 shifter in my truck and i noticed that the bolt patteren is different on a boot off a 205 shifter.
    Thanks :D
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Do you just need the single boot from the set? Our single stick boot is pretty narrow, you might be better off using your 205 boot and just making a plate to adapt the bolt pattern on the 205 shifter boot to the 208 pattern on the floor since that's what you'd have to do with ours anyway.
  3. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    No I need the three boots for the doubler set up. I just built the three shifter setup for my truck. It kind of resembles your shifter setup but probably don't work near as good. Sorry I couldn't buy the whole kit but i'm a broke a$$ and i got more time on my hands than money :D . But if your willing to sell just the boot that would be awsome.
    thanks steph
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Aha! You're also hoping the throw on the levers and the spacing between them works with the boots.....
    Doing both boots, the internal rings and the floor mount ring would be $70.00.
    Add some in there for the 6 heims, the all thread, bushings, handle material, etc and it starts making sense why our shifters cost what they do. Yikes there's a lot of parts!
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Stephen I don't think he understands that your triple shifter uses 2 boots a single boot and a double boot.
  6. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    does that mean you have a inner boot and a outer boot for the setup?
    I'm sorry i confused :confused:
  7. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Here are pics of the boots and plate.
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    That probably goes a long way toward clarifying things, thanks!
