can i lift this way?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevycanada, Jan 7, 2002.
  1. chevycanada
    chevycanada Registered Member
    Aug 14, 2001
    33
    Comox BC
    I know you can use blocks to lift the rear, but can you also use blocks to lift the front of the truck? i've never seen it done but i can't think of why it wouldn't work.
    i just need something temporary till i get the money for new springs
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    NO DO NOT USE FRONT BLOCK'S PLEASE IT IS UNSAFE FOR YOU AND THE PEOPLE AROUND YOU it is illegal in most states for a reason you can use them in the back but never the front
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    No you cant. When you turn it can snap u bolts or break blocks and have a big accident
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yeah lift blocks in the front is a really bad idea. There's several reasons it's not smart... one would be you hit a bump hard enough driving, out they can fly. Then you can end up really messing up your truck, yourself and maybe even someone on the road with you......
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I'm in shape.... round is a shape......
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    NO!
    [Real Men Don't Care About Gas Mileage Or Rapid Tire Wear!]
    Ryan B.
  6. chevycanada
    Aug 14, 2001
    33
    Comox BC
    ok thanks i got the idea.
    now is there any difference between front and rear springs?
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You already got the idea about front blocks but I gotta add ***NO!!!***
    Front springs and rear are different and they are not interchangeable without fabrication.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  8. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    if you have a death wish this would be a way to take care of it
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    How high are you going? ORD has 1" zero-rate-add-a-leafs that bolt to the spring pack and are ok for the front.
    There are many differences between front and rear.....
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Want a cheap lift?
    Get a set of JC Whitney add-a-leaves. Add a set of 3" rear lift blocks. It's a 2.5-3" lift and costs $70. I wish I still had tha and had bought 33s sometimes instead of a 4" and 35s.
    Tim
  11. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    I use 2" traction bars up front with An RMX shock mounted on each one I still flex a 950 on a 30degree ramp have dropped the front end off a cliff into a 5foot hole nothing wrong I have welde plates to my home made traction bars that run between the u-bolts and against the sides of the springs It has run this way for two years on m rig and for 18 years onmy buddys truck and he has wheeled th sh!# out of it. I have learned it the world of wheeling that it is all aboout safety and your own judgement.
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  12. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    spring all the way.....
    Chrome Dont Get You Home...
    and looking at my truck is definite proof...
    1978 Chevy 3/4 - 14" leafs -dana 44w/4.56's -14 bolt corp w/4.56's on 40x17x16.5 Ground Hawgs on 16.5x12 steel rims
  13. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Do you have any pics of your truck? Specifically your suspension setup - anyone ramping 950 on a 30 degree ramp I want to learn from............[​IMG].
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  14. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    If all you want to run is 33s look into a set of 2in springs. You can use an add-a-leaf in the back and 2in springs wont need any other changes.
    "If it aint broke don't fix it" is like a 4 letter word.
    <a target="_blank" href=http://www.phatboy.alloffroad.com>PhatBoy.AllOffRoad.com </a>
  15. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    NO I dont have any pics yet but the most important thing for max flexis soft and flat spring packs. I have a shackle flip in the rear which i fabbed up myself giving me about 7.5" if lift 5 inch block/tractionbar which is connected to fram by way of a shock to keep axle wrap down in the front I have dropped my frnt spring hangers down 5" longer shackles 6" lift springs off of a 68'chevy with top leave removed and stock leaves added to the top and also have a traction bar up front.
