can i make it fit????
Discussion in 'The Garage' started by rubbinz raczn, Dec 19, 2004.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    deciding on lift for my 85 chevy lwb truck. i am planning on running 42x14x15 swamper iroks. i want to bob-narrow the front end so no tire clearance problems. rear wont have a bed so no trouble there. what lift is required to clear firewall with a tire that size? or possibly a 44" tire? i know more lift means more driveline angle issues. i have a set of tc 6" rear springs, but do i need that much lift? the truck is a 1/2 ton so i could swap the 52's from rear to front but how much lift will that give? truck currently has a tc 3" lift with rear blocks. i will be running a d60 with crossover which i have heard needs 4" lift is that true? thanks
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd run the 6" of lift, 42s, and hack it. It'll fit nicely.
  3. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    will the front tuff country 6" springs flex?
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    You can make it fit. Here's 44's on 52" factory springs which is between 4 and 5" lift. Lot of trimming, maybe more to come yet, axle slid forward, maybe needs more, narrowed and so on. Question is can you get everything else to work yet if you make all the mods necessary to fit them. Steering and things like that, hood opening...
    http://coloradok5.com/photos/data/500/10162front.JPG
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Swap the 52's up front. This will net you around 4" lift and move the front axle forward 2". Shackle flip the rear but use a 56" or 63" rear spring so you get more flex out of it.
    Harley
  6. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    so would you use a 56 or 63 lift spring or stock? shackle flip with stock or no?
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The easier one would be a shackle flip with a 56" stock spring in back. should give you the 4" lift to match the front and it should flex ok. If you want the killer flex try and get the 63" springs in with a shackle flip. I know a guy here in AZ has 63" spring on the back of his F250 Crawler and it is supposed to flex like a demon.
    Harley
  8. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    63's it is anyone have any tips?
