Can I paint polished billet aluminum?
Discussion in 'The Garage' started by TX Mudder, Sep 3, 2004.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have a small part that is 6061 billet aluminum, polished and very pretty. Problem is I want it black.
    What can I paint it with? It does not have to be perfect, but it needs to be weather resistant. And should I rough up the polish or...?
    edit: BTW this is an electrical switch and I cannot disassemble it.
    I thought about POR, but I don't know if it will stick to nonferrous metals.
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Not 100% sure, but I think you would have to scuff the surface to get the paint to stick.
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    use a very fine paper...maybe 1000 grit or something like that, then prime it, then paint
  4. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    red scuff pad works nice for parts like that.. the course 3M ones.. clean with denatured, rattle away... a piss coat of zinc is best, and available in rattle, but paint might hold up..
  5. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Welcome to CK5, where custom billet accesories are painted flat balck and dragged across rocks.... /forums/images/graemlins/thumb.gif
  6. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    /forums/images/graemlins/histerical.gif
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    How about powder coat?
  8. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Aniodize..... is the way I would go.
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Anodizing and powder coating and out of the question since I cannot disassemble the part.
    What do you mean by zinc in a spray can? I looked through the spray paints last night and didn't see anything like that.
  10. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
  11. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    zinc chromate or similar self-etching primer
    [/ QUOTE ] Isn't that what the Metal-Ready used with POR-15 is made of?
  12. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] Why? /forums/images/graemlins/screwy.gif Leave it purdy. /forums/images/graemlins/grin.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    why cant you take it apart??
  14. dustyk5
    dustyk5 Registered Member
    Apr 4, 2004
    12
    No disrespect,but you're all wrong,kind of.
    1.is it clearcoated or polished?
    2.if it is clearcoat clean it with dish soap and water,sand with 280 or 320 grit wet paper,wipe with lacquer thinner and immediatley prime with the rattle can primer of your choice,then a couple coats of similar black spray can.(the lacquer thinner softens the old finish just enough to greatly improve adhesion)
    3.If it is polished clean Thoroughly twice with lacquer thinner and sand with 180 to 220.prime with a zinc rich primer as suggested,let dry and sand with 320.prime with standard primer and topcoat with black.
    Dusty(paint man for almost 15 yrs.)
