Can I put 12.5" tires on stock 91 rims?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MousePowrd, May 7, 2003.
  1. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Can I put 12.5\" tires on stock 91 rims?
    My Blazer has the aluminum factory wheels, can I run 32" x 12.5" tires on them, or do I have to get 10.5" tires?
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: Can I put 12.5\" tires on stock 91 rims?
    Yes.
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Yes, I put a set of 35x12.50's on my friends stock K5 and it made the tires nice and tall. Should be really hard to loose a bead too.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    I'm running 38x13x16in tsl's on 16x6.75in rims and they are fine on them /forums/images/graemlins/smile.gif i even air down to single digits most of the time /forums/images/graemlins/thumb.gif
  5. MousePowrd
    May 7, 2003
    215
    Saginaw, MI
    Thanks, I feel a lot better now. Are they really much wider than 10.5" tires when put on a small rim.
  6. gumneck
    gumneck Registered Member
    Feb 6, 2003
    89
    VA
    Tires on my 1991 stock aluminum's are 33x12.50 Pro Comp Mudders and they seem to do fine. They don't give a bulging look to em but they make that rim look small.
    These aren't my tires of choice. Looking to go smaller. Don't need these big-uns for hitting the sands of the OuterBanks.
    Tom
    1991 blzr on blocks
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Out of curiosity, are those stock aluminum rims 8 inches wide or what?
  8. MousePowrd
    May 7, 2003
    215
    Saginaw, MI
    Yeah I am curious about this also. I think that I will go with 32" x 12.5 because I have to tow my boat this summer and maybe next, so it would be more difficult with 35's and a 6" lift /forums/images/graemlins/grin.gif
    Not to mention my wife complaining every time we try to get the kid in the car seat /forums/images/graemlins/ignore.gif
  9. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    I think the aluminum with the round holes are going to be 15x7 and the stock steel ralleys could be 15x8 or 15x7. Check the sticker on your driver's side door. It is in the door jam at the same height as the window.
  10. dyeager535
    26,980
    4wd ralleys are 15x8, 2wd are 15x7. AL I can't remember, but bet its been covered before...
  11. MousePowrd
    May 7, 2003
    215
    Saginaw, MI
    My door says 15x7, and I have the aluminum rallys, but that I think is for the basic wheels for all Blazers. I may be wrong
  12. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My brother used to run 15.5" wide Boggers on 8" rims. Hard to get on, but they went and worked fine... So yeah, I think you should be OK.
  13. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i was told by a fellow CK5'er that the stock aluminum wheels are 15x7, and that is printed on the inside of the wheel....
  14. MousePowrd
    May 7, 2003
    215
    Saginaw, MI
    Thanks, I will check it when I rotate my tires
