can i put 35's on my k5??
Discussion in 'The Garage' started by wisconsin92, Nov 20, 2003.
  1. wisconsin92
    wisconsin92 Registered Member
    Nov 20, 2003
    9
    virginia beach, virginia
    can i put 35\'s on my k5??
    i have read various articles dealing with tire sizes in relation suspension/body lifts and now i would like to know without a doubt if i can put 35's on my blazer with a 4" suspension lift. i have read that it is possible without any modifications, but i have recently read that it will need minor modifications. anyone that can help it would be greatly appreciated.
    GO HARD OR GO HOME..... /forums/images/graemlins/k5.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: can i put 35\'s on my k5??
    Maybe is the best answer we can give....35's fir on my Burb with a 4" TC EZ ride no problem....If I rammed around a lot, then I might consider trimming the fenders a bit.
    Each application is different....
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You WILL need to trim the fenders if you wheel it hard, even with the swaybar.
    The first cut is the hardest though, after that it's all good. By far, sawzall is the best mod I've ever made to my truck.
  4. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    It kinda depends. Lots of lifts and tires dont measure theyre actuall size ( either high or low) lo if you had a low riding 4" and 35's that measure 35" or better you will probbly rubb with thetires turned at full flex. If your truck is mostly on road oriented, It will pretty much work nomatter what. If I was you i would do a 4" susp. lift and 2" body lift. THat will get you your clearance fo sho /forums/images/graemlins/thumb.gif
  5. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Ive got 35's on my worn out 4" lift. So yes the 35's will fit, but I have VERY little clearence between the tire and the fender. It rubs all the time. Comming into drive ways, going over curbes and sometimes when I turn it sharp.
    Nick
  6. wisconsin92
    Nov 20, 2003
    9
    i am planning on getting a rough country 4" lift. the tires i have in mind are interco thornebirds on 15x10 rims. i was on a website that offers a 1" body lift, which seems a touch meaningless since for a few dollars more i can get a 2" body lift that seems a little more sensible. any input with that info??? /forums/images/graemlins/k5.gif
  7. unick
    Aug 16, 2003
    4,286
    if you went with the 4 inch sus lift and 2 inch body. you would be ok. You would clear the 23's easy. I dont really like body lifts but 2" and under are alright.
    Nick
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Might want to do a search on thornturds...err I mean stuckbirds...stuckturds?
    Waste of money, especially if you are buying new. If you find an absolutely smokin deal then I'd consider them but they'd need some major grooving to work half decent.
    Rene
  9. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Picking up my lift from ORD in a bout three weeks. Going 4inch. Tried to buy some 37's but the money didn't work out. 35's will go on instead. Im MY opinion, 35's are like training wheels. They'll work for a while, but pretty soon, your friends will start making fun of you. I hope to have 1-ton running gear in the spring, then the 37's are coming. Probably not gonna do much more for lift, I'd rather trim away and help that rubber stay on the ground. It all depends on how much you like sheetmetal. I've seen a lot of rigs run 4inches and 35's with very minor trimming of the fenders, but I can honestly say that if you wheel anything besides mud, you will rub somewhere...
    Just running my mouth again...
    John /forums/images/graemlins/thumb.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In a way, you're right.
    However....
    Don't upgrade just because your friends think you can't make it where they could. I followed my buddies for years on 35s and they all had 38-44" tires. I finally want to 38s because I really wanted a set of Swampers, already had 1 ton axles, and figured why not go bigger?
    Now I'm trying to resist the urge to go too big, it gets addicting.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]Rough Country ???? I highly recomend that you check the ORD web site out for thier Tuff Country Springs and shackle flip befor you waste your money on Rough Country.
  12. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i have 35s that actually measure 35". they are made by
    mugul and do great. i have a 4" ruff country lift and
    i have plenty of room. i have not yet to rub , but i havent really wheeled it yet. /forums/images/graemlins/rotfl.gif
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Rene
    I will concur with Rene about the Thornbirds. Do a bit of research on them first. You won't find many good reviews. My guess you'd be better served with any of these- Goodyear MTR's, BF Goodrich MT/KM's, Pro-Comp MT, Super Swamper SSR's, Parneli Jones Dirt Gripz, and similar other tires in the 35" range.
    And yes 35's will fit with 4". However they will rub going over curves, around sharp corners ect. It'll scare ya the first time it happens if you've never heard it. Don't worry about it much, it's a good way to find out how much and where you need to trim. Just look for the tire marks on rear edge of the fender lips- Thats where the rubbing will be, and where you need to trim. /forums/images/graemlins/pimp1.gif
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Maybe a picture of where the trimming would be is appropriate-
    You can kinda see the angled cut in the circle. I did that to clear 33's on a 4" lift, with pretty heavy wheeling. The same might be appropriate for you. /forums/images/graemlins/wink.gif
    By the way welcome aboard. /forums/images/graemlins/thumb.gif
  15. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I've got to say that rough country is about the stiffest riding spring out there, right in the league with Pro-comp. And thornbirds? Worthless on road and off. I bought a set new and kicked myself during the entire 20K mile life of the tires. As for what will fit, generally narrow tires on less deep dish rims will fit much better than wider on deep dish rims.
  16. triger
    triger 1/2 ton status
    Jan 16, 2003
    177
    Budd Lake, New Jersey
    <font color="green">I have got 35's and a four incher and it is real tight and does rub when flexing hard...
    Might want to go 6 inches and be average sized... /forums/images/graemlins/rotfl.gif
    T </font>
  17. Curtis2kul
    Curtis2kul Registered Member
    Oct 15, 2002
    62
    Winston-Salem, North Carolina, United States
    i have exactly what you want, a 4inch(all springs) rough country springs and 35inch thornbirds on 15x10 rims, it rubs all the time , i Hate it. It really sucks /forums/images/graemlins/confused.gif But with a 2inch body lift, it will be ok
  18. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i have exactly what you want, a 4inch(all springs) rough country springs and 35inch thornbirds on 15x10 rims, it rubs all the time , i Hate it. It really sucks But with a 2inch body lift, it will be ok
    i disagree about the body lift. i do agree that any sort of wheeling you will rub. i could rub my 33s on 5" of lift during moderate wheeling. the body lift and fender triming will acomplish the same thing but the body lift is gonna make you sit 2" higher. thats gonna make you less stable. cuting the fenders however, will make you sit 2" lower and you wont still rub. thats my .02 cents
  19. unick
    Aug 16, 2003
    4,286
    yea cutting would be better. Im gonna do it soon.
  20. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    However....
    After watching your video I think you and your friends need to put the training wheels back on /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
    And to the other post above, going from 35" to 37" is hardly a jump in tire size that sets you apart from the 35" club.
