can i put dual tanks in my burb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by derikleon, Jul 7, 2006.
  1. derikleon
    derikleon Registered Member
    Apr 21, 2006
    32
    Lawrence, KS
    I want to add another gas tanks to my 77' burb, obviously it just has the rear tank for now. is this going to be hard to do or can it just be bolted up with the use of the factory truck brackets
  2. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    Nope. Pickup rises at the bed area, Sub gets lower to accomadate doors. I want to convert my '87 Sub to veggie oil, and had the same thought. Saddle tanks, but more changes than 1st thought. Even rear shocks upper mount different...
  3. uglytruk
    Oct 24, 2004
    1,329
    Here are some pix of rear area...
    Can't find pix of PU... this is Sub...
  4. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    custom fuel cell?
  5. stkcode
    stkcode Registered Member
    Nov 30, 2005
    86
    Apple Valley, CA
    It's too bad your so far away. I have the tank (no mountings or straps), sending unit, filler and valve from my 86 I planned on parting soon. I can measure the tank if it helps any. It's not a factory setup btw, was done by some trailer shop. The saddle tank had the filler mounted in the driver's side wheel well.
  6. SubYuman
    SubYuman 1/2 ton status
    Oct 13, 2001
    246
    Edwards AFB, Ca
    Aero Tanks
    Makes saddle tanks AND a rear mount tank. I had three on my 79...
    45 gallon rear tank and 2-22 gal saddles, 99 gallons!!! I miss being able to fill it for $100, costs me $138 the othe day to fill my 42 gallon tank. Man I wish someone made a bigger tank for mine....I go 450-470 miles between fillups....about once a week.....
    http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2005698/showCustom-0/p-2005698/N-111+10201+600002071/c-10101/reviewflag-1#review
    EDIT:
    Went to Aero tANKS WEBSITE AND THEY NO LONGER OFFER ALL THE STUFF THEY USED TO FOR OLDER sUBS AND TRUCKS. tHERE ARE A FEW TANKS FOR YOU GUYS THOUGH...i THINK i SAW A 43 GAL. bLAZER TANKS THERE....
  7. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    Are you just needing more fuel room?
    If your wanting to run a 6.2 on veg oil there is no converting to due,if you live in the cold just add a tank heater to keep the oil warm.
