Can I run a PS cooler on the Hi-Pressure line?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zakk, Oct 14, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Already had to slice the line running from the pump to the box, can i place a cooler on that line?
    *edit* and where have other people mounted it? I looked under my truck and the best place for a 17" long 2.5" wide cooler?
    /forums/images/graemlins/1zhelp.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I wouldn't do it. The high pressure side runs as high as 1,200 PSI. /forums/images/graemlins/shocked.gif I don't think the cooler is rated to deal with that.
  3. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    NO, DON'T DO IT!!!!!!!
    your just asking for trouble. the pressure would be way to high for any normal cooler. you need to run the cooler after the box and on the return line back to the pump. Also you need to make sure that the cooler is mounted no higheer than the resivior to help insure that you don't get air pockets in it.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    My factory P/S cooler is mounted under the radiator support.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    ok...time to chop up the line /forums/images/graemlins/grin.gif
    thanks!
