Can I run in 2WD w/no damage if 208 goes dry?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Apr 4, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Checked further into my leak issues last night. Dropped teh shield covering the flywheel and TC before dropping the tranny pan. Turns out I have 2 leaks. One is the rear oil pan seal. That was leaking and hitting the flywheel. The shield was holding it in a letting it just slowly drip from the drain hole. That was coating my front driveshaft and the tranny pan. With new oil and a small leak, it is sometimes hard to tell if it is engine oil or tranny fluid.
    The second leak is coming from my tcase. i don't know if it is the union of the halves or the adapter to the tranny. I suspect it is the adapter. It is leaking a fair amount and I don't have time to deal with it right now. Will it damage anything in the tcase if it were to run dry if I am only running it in 2WD? I don't really expect it to run dry, but I want to be sure.
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I would have to say that running it dry even in 2wd would be bad.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    That would be like running your engine without oil for some time. Sooner or later, something will give... /forums/images/icons/frown.gif
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Very bad, it will toast the t-case in short order.
  5. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Kinda what I figured. That's what I needed to know. I just haven't ever been inside my tcase (yet), so I don't know mechanically how it works. Knowing that would have enabled me to answer my own question.
    Another question now... how much tranny fluid does a 208 hold?
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    As much as it takes to fill it to the bottom of the fill plug. /forums/images/icons/smile.gif
  7. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    About 6 pints I think. Buy 3 quarts of ATF and that should be enough.
  8. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    That sounds like the leaks that I had. I bought a new tranny gasket and filter for like 8 bucks. My np208 was leaking from the hemisphere of the chain housing. I fixed that without dropping transfer case. Just remove Driveline, slipyoke housing and then the back cover just unbolts. Keep everything clean, romove old silicone and add a new bead and reassemble as it came off. No more leak. Took about an hour.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    someone did that to the 208 in the 82, no leaks tha ive noticed yet
    but the front end or something is acting up, keeps making teeth noises up front in hubs everyonce in a while when cruising around in 2hi like its trying to engage into 4x4, we cleaned off the auto hubs real well and replaced them and now its fine in 2hi and now it acted up in 4hi and when it started mking racket i pulled over to tstop and when i put tranny in park there wa sa loud gear scrape grind noise from under truck as if something was still spinning.., wierd.... i dunno what the heck...
    good luck
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sounds like your auto hubs are on there way out. Just get a set of manual hubs and be done with it. I have Warn Premiums, and I like them alot.
