Can I use a 4l60e transmission case to build a 700r4?
Discussion in 'The Garage' started by kyser_soze, Nov 22, 2004.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I have a useless 4l604 that was out of my 98 k1500 before I replaced it. I would like to build up a non-electronic manual shifter for my K5. Would I be able to use this case because the 700R4 is the same transmission without the electronic solinoids? /forums/images/graemlins/thinking.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you cant use the 4l60e case to build a 700r4, the 4l60e case has no spot for the governer.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I thought the same thing, but will he need the governer for the full manual 700?
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    he'd have to buy a manual valve body for a 4L60E, it would still be a 4L60E.
    in 96 or 97 the 4L60E change the output pattern to a 6 hex shape similar to the th400 but its just a little smaller than the th400 pattern, so a special adapter would be needed. if hes using a 208/241 then you could use the factory adapter.
  5. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Wow. I didn't know that and assumed that it was the same. I almost went that route with my 4L60E, and was going to retain my TH400 version 203 for my new Doubler. What does GM think when they do that stuff? /forums/images/graemlins/dunno.gif
