Can I use a 90 CK dash cluster in my 88 Cheyenne?
Discussion in 'The Garage' started by hekg, Oct 4, 2005.
  1. hekg
    hekg Newbie
    Oct 4, 2005
    Miami, FL
    I have an 88 Cheyenne that came with the plain gauge cluster which only has the speedometer and fuel gauges, the rest is just red warning lights. I want to be able to buy one of those newer gauge clusters from a 1990 silverado or some other model with the complete gauge cluster. Will any of these work with my truck? If yes, how can I make all of the actual gagues to function? (temp, oil, etc)
    Thanks for any help! :)
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Do you have the same body style as the donor tuck? You should, just making sure. If the clusters look the same, then you shouldnt have any problem mounting it. Just make sure it mounts up the way you want before you commit to this project. Now, the fun part is in the wiring. You need a wiring schematic for the cluster, Chilton's would probably be a good source for that. You need all of the sending units for the respective gauges. Those shouldnt be a problem. You can get those from a junkyard or from a parts store. And you neeed the harnasses or connectors that go to the sending units. Hardest part is gonna be in the wiring.
    Good luck...
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    you should be able to use any 80-89 k5 cluster, and 80-87 truck cluster.
    in 1990 they changed to electronic speedo. everything else should be a plug 'n play deal.
  4. hekg
    hekg Newbie
    Oct 4, 2005
    Miami, FL
    Great .. My truck is the 88-98 syte and the cluster appears to have the same plug as the plug on the one I want to get.
    What about the sending units? I'm not too familiar with these or where to find them and probably more important what to connect them to. :)
    I guess the chilton's manual will clear this up some. Thanks for your help! :)
