Can I use a Ford Dana60 on Chevy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73k20, Jan 24, 2002.
  1. 73k20
    73k20 Registered Member
    Jul 6, 2001
    59
    South Louisiana
    Does anyone know what I would have to do to mount a Ford Dana60 onto a Chevy truck? The pinion is on the passenger / righthand side and is a high pinion axle.
    Who said size doesn't matter?<P ID="edit"><FONT class="small">Edited by 73k20 on 01/24/02 10:27 PM.</FONT></P>
  2. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    adapt a ford tcase, (Lh front output) or divorce mount a ford tcase to have the fron driveshaft line up. Also probably need some mods on the spring perches and shock mounts.
    -matt
    <font color=purple> "Stuff's only good for 2 things, degreasing engines and killing brain cells"</font color=purple>
    <a target="_blank" href=http://www.geocities.com/shaggyk5>www.geocities.com/shaggyk5</a>
  3. 73k20
    Jul 6, 2001
    59
    South Louisiana
    I guess all I'm really concerned with is the spring perches and possibly the steering. Does anyone know the distance between the front springs on a Ford?
  4. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    The pinion on a Ford has always been on the drivers side are you sure you dont have a Dodge axel?
    Corey 78K5
  5. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Hi,
    Ford Dana 60s from 1978-1979have the same center pin hole to center pin hole, witch should be 47.5 inches. What ever the number is i know it is the same as the GM front ends. I plan on this same swap with a 203/ford 205 set up. Steering would be the same as GM Dana 60s b/c they are both king pin style. The 1986-1996 ball joint style will not bolt in, they have a different perch distance.
    Make sure you get the under axle u-bolt plate for the drivers side, don't worry about clearence because your diff will be lower than the u-bolt tips The pass side can be over axle style
    Hope this helps
    RUss Vassar
  6. 73k20
    Jul 6, 2001
    59
    South Louisiana
    Thanks for the info Russ,
    It came out of a 1992 Ford. I guess I'll just keep looking.
  7. RUSS84K5
    Jan 9, 2001
    172
    NEW HAMSHIRE
    if it is a good price then you could make a few bucks, mabey get the 60 you want and pay for the gears you need from the sale of the 1992 dana 60.
