can i use f250 HP44 backing plates on my 10bolt to convert to 8lug????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 01maroonz71, Jan 9, 2007.
  1. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    well, i was at the yard today and they have a 79 f250 LD truck with the HP44 8lug axle and i was wondering if i could buy the backing plates off that truck to convert my 6lug to 8lug...im going to buy the hub/rotor assemblies new at autozone for 69.99 but i cna't find backing plates anywhere....also is this all i need to do the swap???? thanks guys!
    ~Dave
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well the ford typicaly has 5 bolts on the spindle while chevy and jeep have 6
    you could buy the axle sell it (HPD44 are not cheap) and buy the chevy outers you need.
    :D
  3. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    the axle is missing the shafts, but otherwise is complete...i did think about buying it for another project and runnin some chromoly shafts, but i think i need to focus on one at a time...haha....i guess the search continues.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    to do that u would need to swap everything from the outer knuckle out, including the outer axle.
  5. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    Or you could redrill the backing plate to match the chevy d44, but then you'd need ford calipers. There may be a difference in the rotor diameter as well, not sure there. :thinking:
    Probably not that hard to do unless they are cast, but even then it's possible. Just be patient.
    Later,
    Buddy
  6. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    yeah, im just gonna wait...all my buddies say since it's basically just a mud truck to get 6lug wheels up front and 8's in the back, then when i eventually get a 60...to just buy 2 new wheels for the front....dunno though. i geuss there's no sense in investing money into the toothpicks now....
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    8-lug 10-bolt axles are pretty easy to find around here for $100-$150, and they typically had good rotors and even bearings in them. Back in the day when I did the conversion I paid $50 for the 8-lug hub/rotor assemblies and backing plates out of the junkyard. Repacked the bearings and bolted everything on.
  8. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    dang, i wish it was the same way down here...i can't find an 8 lug ANYWHERE LOCALLY...if you could go and pull the hub/rotor/backing plates i would be willing to pay you for your time if you could ship them to me. how does that sound???
  9. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Doubt you could afford me:wink1: Can't hardly find any time to work on my own stuff.
    Hell, the local junkyard guy just cut the knuckles on the axle with a torch and handed me the setup with the shafts still attached.....even after I offered to just unbolt what I needed.
