Can I use stock steer pump w/ my AGR box?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, May 17, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Or do I need to install the 'Super pump' that AGR offers?
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    You can use the stock pump. I do, kpanza does, as do others I believe. No problems in my case, but only been driving it for 3 days.
  3. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Yes you can. AGR just bumps the pressure up on them a little other wise they are stock. If you want to bump the pressure up yourself you can. Take the main fiting of the back of the pump and pull out the piston that is behind it. On the other end of that piston is a nut with a small screen in it. That nut will either not be screwed in all the way or will have a small shim or 2 under it. Remove all those shims and then tighten down all the way and reassenble it the same way you took it apart. and you will have an AGR pump
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i wouldnt reccomend it they cost tooo much , i have an agr box and a crappy pump which i did that remover the shims mod too and its still needs replaced er sumpin so i may try the next mod cuz thats easier that changing the pump....
