Can I use wood for lift blocks?
Discussion in 'The Lounge' started by chevyracing, May 8, 2003.
  1. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I need to make my 31 inch mudder tires clear the fenders without doing any sheet metal work..
    I was thinking that I would use a good quality hardwood with a real tight grain, something like Red Oak for the lift blocks. I could drill a small hole in the center of the board for the Center Pin to ride in. I am not going to take any chances so I will put a couple of hose clamps around the pieces on the front lift blocks for added safety in the unlikely event the wood cracks.
    I like the options on the available "lift" sizes. The only thing is if I were to use a 4 inch thick board I believe it is only 3.5 inches in real time measurements, so I may have to get a 4 inch board and a 1 inch board and put them together to get a full 4 inch lift.
    My questions are these:
    1) Should I use nails, screws, glue, dowels or a combination of any of the above to hold the 2 pieces of wood together for the full 4 inch lift.? (I want this to be safe)
    2) I will probably need to use a good preservative on the wood to keep it from deteriorating. (sometimes there are puddles of "liquid" in the mall parking lot). Should I use a good sealer like Thompsons Water Seal or should I use a poly eurethane.? I used Thompsons on my deck and it beads water off quite nicely and it came with a sticker.
    3) Should I use a router to finish of the edges of the boards to prevent chipping or splitting?
    Thankyou for your time on this tech question.
    John
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Nice post !
    I hope your kidding, April Fool's
  3. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    I think a good pressure treated 4x4 would do ya up right. You can use some latex black gloss paint on it and it'll look like metal (sort of).
  4. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Use Balsa wood...so much easier to shape to your needs and it's a real weight saver!!/forums/images/graemlins/rotfl.gif
    For that faux steel look you could wrap it with sheet metal flashing...the pop rivets would give it a real faux hardcore look similar to beadlocks./forums/images/graemlins/grin.gif
    The possibilities are limitless, 2x4 shackles, stucco for rust repair, house wiring for the stereo...maybe even the residential fuse panel. Just think, no more fuse replacement!! Then there is the ever popular fake wood grain panelling and shag carpet...a real must for any hardcore wheeler!!
    Rene
  5. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    Just keep the 'Orkin man' handy in your phone book - I'd hate to see your lift go away because of termites /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Jon /forums/images/graemlins/burb.gif
  6. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Use Ironwoods or IPE Very dense wont rot. Use ceramic coated screws /forums/images/graemlins/grin.gif
  7. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    Good advice, thanks. I do have a mobile phone in the event termites should appear.
    John
  8. mudgition
    mudgition 1/2 ton status
    Oct 31, 2002
    110
    cowlitz county, wash
    Something that works for me is wrapping your blocks in leftover metal flashing from any roofing project. /forums/images/graemlins/thumb.gif
    If you put the seem on the top of the block it gets covered nicely by the leaf spring so no one knows. /forums/images/graemlins/wink.gif
    And the added weight is offset by the added strength. (I hope). /forums/images/graemlins/thumb.gif
  9. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    If you use styrofoam, just think how much nicer those deep water crossings will be when you float across... /forums/images/graemlins/deal.gifAnd don't forget the silver paint... /forums/images/graemlins/eek.gif
  10. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I'd probably go with a softer wood, they ride better. NAILS?!?!No way, might split... use some good wood glue (Elmers)...better to be safe then sorry. I'd router purely for asthetic purposes. Yes a good sealer, but first I'd go with a nice pecan stain then finish with some 150grit.
    -After you're done take it by CHP for inspection...you'll be fine.
  11. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    you could use dowells for tie rods, and any good quality
    wood for the lift blocks,
    but what if a (beaver) chews them apart, /forums/images/graemlins/1zhelp.gif
  12. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Just weld the wood blocks to your spring perches, that way they are less likely to split and fall out. /forums/images/graemlins/thumb.gif </font>
  13. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Don't forget to pre-heat the blocks really good though...the E70oak18 rod works best for wood IMHO./forums/images/graemlins/grin.gif Gives a whole new meaning to the term "Root pass"
    Rene
  14. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I wouldn't trust wood at all, too hard to clean. I think fumes hit the mark with styrofoam, though. Or, if you have a suscription, folded up old newspaper would work good, best in mud.
    Rene's idea for the wood paneling is awesome, sparked another idea for me. I might have some tile left after my bathroom remodel job, maybe I'll use it to replace the rusted bed in my truck.
  15. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How about old phone books, They come in several different thicknesses up to 4" thick. You could also rwrap them in allunminum foil for the *BLING* effect.
  16. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    If i decide to hang red lights on these I will have to run two wires instead of one, forgot about the ground wire...Darn. That just doubled the cost of wire. /forums/images/graemlins/mad.gif
    John
  17. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    Them mean ole beavers better stay away from my wood!!
  18. The_Beaver
    The_Beaver Registered Member
    May 7, 2003
    11
    Beaver Dam
    Mr. Chevyracing, I don't know what sort of beavers you are accustomed to associating with, but anyone who is at all familiar with our species should know that 4" of wood will not satisfy an adult beaver.
  19. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Dang Cork! Ya beat me to it... /forums/images/graemlins/thumb.gif
  20. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
