Can i weld in new 8 lug centers on a wheel? *DELETED*
Discussion in 'The Garage' started by K1Orion, Feb 2, 2003.
  1. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Post deleted by scottsdaleorion
  2. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Re: Can i weld in new 8 lug centers on a wheel?
    Don't do this. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    15' 8lug wheels are so cheep don't risk yours, mine, theirs saftey.It's a bad idea and to be honest I think your a fool if you do it. If your set on doing it take it to a professional wheel shop and have them do it.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I agree fully with the above statement.
    Go to a junkyard and pick up one for $5, or buy a brand new, painted, and shiny one for $35!!! It's not worth the hassle to weld in new centers.
    It can be done though...like on hummer rims when someone orders custom backspacing, but it takes a special setup to have it done right, and a good weldor.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    where do you get 15" 8 lugs for 35.00???
    nathan
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you can weld really well then go for it.
    you have to be at least as good as the minimum wagers that are building $35 wheels
  6. heavy4x4
    Aug 28, 2002
    3,270
    click here I was off by $5....sorry. This is the Summit number - USW-70-5080.
  7. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    I kinda figured this was a bad idea but I am willing to try anything. I didn't realize 8 lug 15" wheels were that cheap. Thanks everybody
  8. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Not a good idea unless U R good welder.That said,I found out that the centers from stock 16in 8 lugs will fit.Knock out the rivits on 16s and[Hard Part} cut/grind centers out of 15s.16 centers are tight fit in 15 wheels.You have to set the proper backspaceing and make sure there's no runout.I use old spindle hub to rotate mine before welding.After you make a couple wheels you'll see why most people buy new ones.It's not easy to get it right. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    heavy 4x4
    thanks for the link
    nathan
