Can I wire my alarm to honk the horn instead of a siren?
Discussion in 'Audio' started by zcarczar, Oct 31, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Would anybody know how i could go about doing this? Those stupid sirens bug the heck out of me.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thats the whole point, the sirens is suposta bug the heck out of you. I wouldn't change the way it is designed to work.
  3. zcarczar
    Feb 10, 2002
    2,495
    well yeah i know, but all you have to do to disable the siren is pop the hood and cut the wires, but if you wire it to the horn its going to take a lot more than just poppin the hood and cuttin the wires going to the siren.
  4. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    It would be fairly easy to cut the wires on the horn as well....
    To make them work with your alarm, you will need to use a relay. The output of the alarm can be used as a switch to operate the relay.....good luck!
    /forums/images/graemlins/k5.gif
  5. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    or he could just buy a battery backup siren.. this way if they cut the wires it still keeps blaring away..
  6. zcarczar
    Feb 10, 2002
    2,495
    Prembird, where might i get one of those? and how would i wire it up to the relay, i forgot the correct inputs.
  7. Prembird
    May 15, 2001
    811
    kc, mo.
    anyplace that sells car alarms will have then.. basically you just put it in place of the siren that came with your alarm.. if the alarm gets set off then the siren goes off.. if they pop the hood and cut the wires it still goes off... now the down side is that if you disconnect it then it will go off since it no longer senses power coming from the alarm brain... so if someone crawls up under it and cuts it it will automatically start going off...
  8. zcarczar
    Feb 10, 2002
    2,495
    Alright, so if i ever need to disconect my battery its going to go off for a long time? Is there anyway i can pop out the battery when I dont want it going off?
  9. Prembird
    May 15, 2001
    811
    kc, mo.
    you will need to check with the manufacturer if there is a way to shut it off.. otherwise... just shove a sock in it and the battery will last about 30 min. or so...
  10. Grim-Reaper
    7,385
    Atlanta
    Yeah it can be done with a relay and Turnsignal flasher (to make it beep on and off and not continuous. You can also make the lights blink the same way if the alarm doesn't have the provision.
  11. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    A pulse timer would also work for the horn.
    If you want a battery backup siren give me a shout I think I have some instock right now, but I'll have to check.
  12. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    of course, they could always pop the hood and cut the horns wires, or pull them off of the horn contacts
