Can I...
Discussion in '1936-Present Suburban' started by SubYuman, Feb 6, 2005.
  1. SubYuman
    SubYuman 1/2 ton status
    Oct 13, 2001
    246
    Edwards AFB, Ca
    I was given a 205 transfer case and was wondering...
    I want to do a SFA swap eventually, can I add the transfer case now and run it? It even came with the cross member. Also, where can I put the shifter so it won't mess up my fride console between the seats?
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    it will be a lot of work to run it now.
    you will need the right adapter to your trany, shafts will be the same, but the speedo out put will be for a cable and your truck will be a wire.
    on a 205 the shifter comes right up from the from of the case, so eather move the console back or you will have to cut and fap a new shifter.
    seen a pic in the gallery of some ones devorced 205's shifter.
    dont know who
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    2wd trans will have to go. I'm not sure but think you have a 4l80E so thats a pain to lose and replace. Call Advanced Adapters and see if they have a setup to mate a 205 to a 2WD 4l80E. Speedo setup may be a pain and you NEED it with an electronic trans.
  4. SubYuman
    Oct 13, 2001
    246
    Edwards AFB, Ca
    speedo offset in low range...
    I doubt I will ever need a speedo if I am offroad in lowrange, never did in my old 79 rig. SInce the speedo is run off the outpput sensor, having the case in low will just skew the #'s when its in low right?
    Next question then would be, is there a better case for this setup?
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Maybe look into a NP 241....I am not sure if you just swap the outputshafts and get the adapter or not. The 241 will have a lower low range too.
    Or, just
    divorce mount that 205....
