Can it be? A 11.5" or 12"........ 14 bolt GM corp axle
Discussion in 'The Garage' started by **DONOTDELETE**, Oct 17, 2002.
    Can it be? A 11.5\" or 12\"........ 14 bolt GM corp axle
    I just received my new Performance accessories catalog last night and while thumbing along I came across those Mag Hytec Dif covers and proceded to check out the pricing. The thing I noticed was that they offered a dif cover for two different GM 14 bolt Corp axles, hmmm so I think 9.5 and 10.5 OK, NOPE it was 10.5 and a 11.5" cover. WTF? Is this something new or what? Any info on this axle? I checked at the Hytec website and they only offer the 10.5" dif cover, but in the coming soon they mention a GM 14 Bolt in a 12". Another WTF came to mind !! Just when we think we have all the axle info fugured out they go and put a wrench in your spokes.
    On another note while speaking about axles. What size is the ring gear in a Dana 44 ? LMC catalog shows it to be 9 3/8 I think it was, but the axle I.D. chart on CK5 show 8.5 and that is what I thought they were. Is it the HD Dana 44 or the rear Dana 44 that is a 9 3/8 ?
  1. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Re: Can it be? A 11.5\" or 12\"........ 14 bolt GM corp axle
    The 11.5 ring gear axle is in the new HD GM trucks--haven't heard about the 12" ring gear though. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. Re: Can it be? A 11.5\" or 12\"........ 14 bolt GM corp axle
    That's what I figured, but wanted to check with the CK5 crew !! Next questions are: Do they make this in a single rear wheel design? How much bigger is this beast, as in axle diameter, weight, ground clearance, does Detroit make a locker for it yet, ect...
  3. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    Yeah they are avaliable in both single and dual wheel configuarations, not sure about the specs. GM dealer should have the specs on them ie.,weight, axle id, spline count and dimiensions. I would call tratech direct or 4WP about the locker /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I have the 11 1/2" axle under my '01 GMC. Ground clearance is horrible, hangs a couple inches (guess) lower than a 10 1/2 incher. The axle has a harmonic damper on the pinion, which would also be a liability off-road. I haven't pulled an axle shaft yet to check diameter and splines, gotta do that. You would really have to want something bigger than a 10 1/2 incher to try to use this axle in any kind of swap. I know that Dodge is using AAM (GM corp.) axles under their new HD trucks, so there may be some more versions floating around soon. I have to go look at one of the Dodges, as I think they may be using an AAM solid front axle under them too (first AAM solid front ever?). I am curious what diff they started with to build that (9 1/2")?
  5. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    mayby i should go take a closer look at the 14 in my wifes 02 2500HD. i had no idea there was a change. /forums/images/graemlins/eek.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I have a couple images of new dodge AAM front and rear difs
  7. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    LMC is on crack...it's 8.5" /forums/images/graemlins/rolleyes.gif
    The larger 14 bolts would be a liability off road cuz of clearance issues...and the extra ring gear size just isn't necessary for out purposes.
    Rene
  8. Blazer1970
    1,600
    Old Mission, MI
    2500HDs with the 6.0 l engine get the 10 1/2" 14 bolt. 11 1/2" is in Dmax and 8100 trucks only.
  9. Blazer1970
    1,600
    Old Mission, MI
    So? let's see 'em!
  10. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    Didn't realize the 6.0 2500HD and 3500HD's came with the 10.5 rear axle. I thought it was just the regular 2500 not the HD's. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  11. sapper
    Jul 11, 2001
    3,052
    NoVa
    ok thats why it looks just like mine yes yes i got the wimpy engine oh well /forums/images/graemlins/eek.gif
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    my webshots has been limited so I am emailing them to you
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    "9-3/8"
    10 HOLES
    OVAL Gasket Pattern "
