Can it be done?
Discussion in 'The Garage' started by rock.monkey, May 24, 2003.
  1. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Can I put a Guage cluster with factory tach. from a 78 into my 88 without too much hassle?
    I did a search,but didn't find what I was looking for.
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    as far as fitting in there i know it would wokr..but connections im not sure ive never seen the back of an 88 gauge cluster..they might be a little different..not sure though..
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sure you can... long as you dont mind cutting and pasting... heh actually i have no idea whatsoever, but you knew that already, didnt you?
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    It will physically fit, but the wiring is all different. Warning lights and stuff. Older truck doesn't have a check engine light. If you want to make a harness, you can!
  5. Grim-Reaper
    7,385
    Atlanta
    Not if your 88 is still FI. The VSS is in the back of the speedometer.
  6. rock.monkey
    Oct 28, 2000
    296
    Good thing I picked it up free then.
    Thanks.
