Can one of you guys help me with this? Ignition/timing issue
Discussion in 'The Garage' started by Zeus33rd, Feb 9, 2003.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Or atleast maybe give me some input on what to check....
    Here is the link to the post on the Nor-Cal Big Dawgs forum. Any ideas from ya'all? /forums/images/graemlins/1zhelp.gif
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    id say proably the battery cables proably either corroided or not making full contact at battery or block/starter also check starter ground (make sure block is not dirty between starter and block and check to make sure the starter bolts are tight) hope this helps
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I guess I forgot to post this on that post, but the starter,and cables are new. And the battery is good. Just swapped the starter 2 days ago. Replaced a couple ground wires too. Thx tho..../forums/images/graemlins/thumb.gif
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i think someone said to check the timing chain already.but that is what it sounds like to me.ive never done one but it looks like a pretty simple fix.i always wanted to put a gear drive timing in mine.if i ever have problems that is what im putting in.never have to worry about changing it again.hope u figure it out.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    my lecture was posted /forums/images/graemlins/thumb.gif
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Thanks for the reply Zak. But I did figure out the problem today. And it wasn't ignition or timing related. I pulled the valve covers off to watch the rockers....The #6 intake was barely moving. Seems that I have a flat cam lobe. /forums/images/graemlins/frown.gif I need to get a Geo.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    damn. cams are pretty cheap. labor intensive to install by can be had for $100
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yeah, I'm gonna be ordering up a Comp Cams Extreme 4x4 Cam soon as I sell my 205 to pay for it. $99.95 from Summit. Anyone need a 10 spline 465 version 205? /forums/images/graemlins/1zhelp.gif
