Can send but not recieve
Discussion in 'Communication (CB | GPS | HAM)' started by txfireman110, Nov 4, 2003.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I have an $80 dollar CB in my rig and I think it is a good one, at least I did like it before. Recently though, I am able to send and be read clearly, but I am not able to recieve and I have done the obvious such as check the volume, the antenna, the cable, and the connections and all seem to be in good working order! Any suggestions? /forums/images/graemlins/1zhelp.gif
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    If it isn't anything like the antenna connections or knobs/switches in the wrong place etc then you probably have a real problem.
    Have you tried listening to another radio transmitting really close(like a few feet away)?
    Do you not here ANYTHING? as if the squelch is turned up? (it isn't right?) Does the radio indicate at all it is receiving anything? Signal strength meter/lights change?
    If the radio "looks" like it is receiving but you aren't hearing anything then it might be as simple as a blown speaker or a loose wire in the microphone cable(some radios have to have a wire grounded in the mic to activate the speaker).
    If the radio doesn't show any signs that it is receiving signals then you might want to find another cheap radio or find a local cb shop to check it out.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Make sure it's set to CB and not PA. Turn RF gain all the way up and squelch is down.
