Can some help me????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue86, Apr 11, 2002.
  1. bigblue86
    bigblue86 Registered Member
    Jan 11, 2002
    53
    East Texas
    I just bought a 14 bolt rear ff and I have no Idea what the gears are in it. It came out of a 77 van 1 ton 8 lug can someone so help me or tell me were to look to get a code off of it. thanks
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Drop the cover. It should be stamped on the ring gear somewhere. It will probably appear in the teeth code.
    41:10 = 4.10
    41:9 = 4.56
    something like that. divide the first number by the second number and you get your ratio.
  3. 1975k5
    1975k5 Registered Member
    Feb 28, 2001
    44
    Alabama
    rotate the axle 1 revolution and count the number of times the input shaft turns. If the input shaft turns 4.56 times, then you have 4.56 gears.
    Hope it helps. Tom
  4. bigblue86
    Jan 11, 2002
    53
    East Texas
    I think I came up with 3.73 this may not be right if it is a 3 73 I am going to thow it a way. its only 75 bucks I guess u get what you pay for. HUH
  5. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    DO NOT THROW IT AWAY! If it is in fact a VAN 14BFF, I want the axle shafts. Where are you located? PM me at my yahoo address....
  6. k5wantabe
    k5wantabe Registered Member
    Sep 3, 2001
    30
    So. Cal. Lancaster
    Fill out your bio so people know where your located. Some one near to you may want it.
  7. bigblue86
    Jan 11, 2002
    53
    East Texas
    dodge_diesel_cowboy_69 on yahoo messanger or @yahoo.com for e mail
