can some one help me real fast
Discussion in 'The Garage' started by k5freak44, Mar 7, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    how do you take this thingy off.
    i circled it in yellow.
    thanks guys
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    this aint no gay site, and now im not gonna help you
    you need to compress the spring that is behind it to get the snap ring that holds it off. you can get the lock plate compressor at autozone.
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Little circlip around shaft.
    Small screwdrivers and cover with rag when about to pop off so you don't lose the little bugger.
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Push in on it and there is a lock ring in the center around the steering shaft. That plate has tension on it from the spring and the lock holds it all together. I made a puller but you can buy them from the parts store. Makes it alot easier.
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    more like gay song playing on your radio. thong song went out with velcro shoes.
  6. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    what song are you listening to on your radio.......Thong song????
    Use the tool said above, just buy one instead of borrowing it, they're cheap.
    Steve
  7. goldwing2000
    goldwing2000 Guest
    Big Hammer and an oxy/acetylene torch, same as everything else.
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    C'mon, you can get this by hand...... ;):D
    (not the ghey stuff, the clip:p:)
  9. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    thanks guys i really appreicate the help.
    why cant yall find humor in my cropped image :(
    im supised no one said anything about my speedo.
  10. goldwing2000
    goldwing2000 Guest
    LoL... missed the speedo. I did see the radio, though. :D
  11. dyeager535
    26,980
    Just figured you were from Canada. :confused:
    As has been mentioned, go buy the lock plate compressor tool. $10 at any major auto parts store, and WELL worth it. Removing the plate isn't that tough, installing it by hand sucks.
  12. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    alright guys, i got the plate dealy, 20 bux removed it, couldent get any further and didnt want to mess anything up for they day, so i started putting everything back togeather and when i was pulling my steering wheel back on the car decied to go into gear. parking break didnt do a dam thing, blazer rolls down steep driveway into the back of sisters care while i try to stop it and nearly get run over in the process. ankle is sprained, steeringwheel is still broken, sisters 4runner is smashed.
    what a great day
  13. dyeager535
    26,980
    Damn, that worked out to be an expensive exercise.
    No offense, but those of you who don't use your ebrake, pay attention. (yeah right, we'll just keep using the transmission and expect that to never fail us) Don't care where you live, or what you are doing, things like this can and do happen as evidenced here, and there is NO reason for the ebrake to not be used.
    I'm really not much for crazy safety rules and such, but it's not hard to use the ebrake. I hate seeing vehicles damaged for something as simple as not using the ebrake. (or not making sure it at least works, then when you need it, like the brakes fail, it doesn't work)
  14. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    e brake was being used and i did have it on. just found out today it dosent do anything in reverse.
  15. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Went into gear? Running? Came out of park? What the hell?!?!
    Glad everyone is ok (relatively speaking).
  16. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    yea my steering colum is loose at the tilt, and when my steeringwheel moves my shifter wiggles around too
    i guess turning the wrench popped it in reverse and it rolled.
  17. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Were you pulling the tilt apart to try to get the slop taken out? If so it was probably more than what you were prepared for - there is another specialty tool you would need and the instructions for how to do it (so it doesn't happen again ;) )
    Anyway that fokin sucks. Let us know if you need the tilt wheel fix instructions. Someone will have the link.
  18. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    i knew what i was getting into and i had my haynes manual along the way to help me. my parents kept buggin me about fixing it so when i finally started to morethings happen. they took it to the the dealship while my ankle slowly stops swelling.
    it will be fixed by thisevening.
    thanks tho
  19. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    OK, not something that could have been done 'real quick' like but I guess you know that now :D
    On a lighter side I did not think that you could get a vehicle to freewheel/roll anywhere in Texas :whistle::rotfl:
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    oh boy... i can only imagine what the stealership is gonna charge to tighten and loctite the 4 bolts it takes to fix a wobbly column. i can do it in about 15 minutes. (the right tools help immensely- $20 lock plate compressor, and a $20 Snap-On pivot pin puller)
