Can somebody measure their stock blazer for me?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Batmanjr, Jul 31, 2003.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I just got done putting a custom lift on the truck and em curious at where I'm sitting at! Could someone please measure from the concreate to the beauty line on the their stock blazer.......... One measurement from the front fender, and one from the rear fender..... Thanks! /forums/images/graemlins/thumb.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Beauty line? Is that the trim line??
  3. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    check out the tech psecs here for your year blazer. it will give you stock heighth.
  4. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    What year model is it? I've got an 84 that is stock with 31x10.5 on it. If you want I could measure that for ya. Just specify what you mean by body line so I can get the right measurement. Or I can just measure from the ground to the bottom of the rocker.
    Kris
  5. Batmanjr
    Mar 23, 2001
    1,537
    Beauty line = trim line!
    it's the only relative line I still have on my truck! The rackers are gone, the fenders are trimmed and it's the most constant item that's still there! Year, 84 will work! I would be most appreciative if you would measure that for me! Thanks!
    The problem with the tach section is it doesn't give adequate measuring points for highly modified trucks! I don't have stock bumpers, and the truck has no ground lines any more! Thanks though! /forums/images/graemlins/thumb.gif
  6. Batmanjr
    Mar 23, 2001
    1,537
    Still need these measurements! Thanks guys! /forums/images/graemlins/thumb.gif
  7. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    16" from ground to bottom of rocker.
    Edit: oops, didn't see you don't have rockers /forums/images/graemlins/ignore.gif Not everybody can afford that fancy-ass trim! /forums/images/graemlins/tongue.gif /forums/images/graemlins/rotfl.gif Anywhere else I could measure to?
  8. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    shound measure to an area on the frame.. then add for body lift if you have one.
    mike
  9. Batmanjr
    Mar 23, 2001
    1,537
    Do you know that bend in the sheet metal, right above the wheel wells that go all the way down the side of the vehichle and is supposed to be straight! That is the line I'm refering too...... Can I please get a measurement from the line on the front fender to the concreate, and from the line on the rear corner panels to the concreate.... That would be great!!!!! thanks! /forums/images/graemlins/thumb.gif
  10. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Bruce, I have a stock 1980 beat to crap Blazer sitting in the shop with bald P235 15" tires on it. The front measuires 39.5" and the rear measures 43". There is not lift just old age on this crate.
  11. Batmanjr
    Mar 23, 2001
    1,537
    Thanks man, I really appreciate it! That's close enough! I'm really just looking for an estimate to see where the 63" rears and the 52" fronts left me sitting! thanks alot! Bruce! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  12. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    OH, gotcha. I'll measure in a few if you still want me to, or is 45acp's measurement good enough for your purpose?
  13. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    do you still have the stock bumpstops? if so thats the most accurate way to measure lift. from the axle tube to the bumpstop mount face. unless your wanna know how high combined with bigger tires. my truck was 9" in front. dont remember what it was in back, i could find out tho
