Can someone explain the TV cable to me?
Discussion in 'The Garage' started by sled_dog, Sep 15, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I am thinking about swapping one of the 700R4s I have sitting into my next project instead of the SM465. Will lose a lot of gear but would gain the not dealing with a clutch. With a full manual valve body is a TV cable neccessary? I know my dad never runs kick downs on his TH400s in his race cars.
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    290
    Truckee, CA
    Keep that sm465 in good shape, and don't hack anything (clutch assembly/bracekts for pedal) when you remove it, and you should be able to get some good $$$ out of selling it.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    TH 400s do not have kickdown cables or any type of cable for that matter, the kickdown is electric on a TH 400.
    TV cables are often thought to be the same thing as a kickdown cable, but the function of a TV cable is far different.
    And if you run a full manual, no, you won't need it, it will apply full line pressure all the time and obviously you'll have to shift yourself.
    With as much gear as you'll have I think I'd want the 465 though.
    don't you already have your driver drop 241? If so, you realize you'll need a different one or an input swap to go to a 700R4, right?
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    <a href="www.tvmadeez.com" target="_blank">clicky</a> check out article 101 Link doesn't seem to work but it's www.tvmadeez.com /forums/images/graemlins/thumb.gif
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the TV stands for throttle valve cable. its preaty much a throttle position sencor for the tranny. as more throttle is applied, the cable pushes a plunger and raises the line pressure.
    the line pressure affects the shift points and the when it down shifts.
    thats the short version
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I can get either 241, I have a 32 spline version right now but could just as easily get a 27 spline driver side drop. I was thinking going Atlas if i go auto anyway.
